well shit i wish i really had someone around here that would set it right but everyone right around my town and shit they do not know anything about this shit lol or know how to tune it right
Ahh, damn.
Yea, my friend came to me when he got his subs.
You could buy a DMM ($10-20) at Lowes, Home Depot, Ace Hardware, and/or Radioshack. Set the gain with that. I'm not sure what it should be set to but I'm sure someone else who's reading this can help you out.
You can also set the gain by ear. Start a 50hz tone or whatever, turn the head-unit up to 3/4 volume (make sure amp gain is all way down too), turn the amp gain up, once you hear distortion, back off on the gain. Do you use the Kicker bass knob also?
OT: When I was living with my dad, he just cranked the gains all the way up... ugh.. I thought it was the LPF (LOL!!!) so I turned it all the way down, bass sounded a lot cleaner. :)
to get the most bass out of them you got the have them all the way up right????
omg :blink:
so ur gain should be set to match the rca/preamp voltage ur headunit puts out
bass boost can be used but only use it on the knob or amp, not both
u are causing major distortion issues.... i have never once used or seen a system that needed 100% gain, 75% at most for 2v headunits like alpine
Ahh, damn.
yes i do use the kicker bass knob that is how i turn my bass down and up i do not hear any distortion unless i am not listening to the samething ya'll are lol
here is a vid i did like 15mins ago can not see alot of flex b/c my camera sucksssssss my trunk looked like it was going to blow off lol
hold on it is uploading
What is the voltage your head-unit puts out for the sub pre-amp output?
Set the gain with the bass knob all the way up.
Sometimes, you can't hear distortion, although, the amp is more then likely clipping (but not audible) and sending a clipped signal will make the sub VC heat up faster and the amp tries to put out power it can't produce, overheats, and blows. Usually, the fuse would prevent that from happening, I don't know exactly though.
i do not know what voltage my head unit puts out for the sub pre amp out put how can i find out????? and where should i put the crossover feequency on the amp half way or 50hz or 200 hz?>???
ur preamp voltage should be listed in the manual
u should set ur crossover to about 80 hz
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
ok i got a DMM but do not know where to put it so i can set my gain i got
dcv/500/200/20/2000m/200m
then i got ohms/2000k/200k/20k/2000/200
dca/200m/20m/2000u/200u
acv/500/200
and do i have to play a tone to set it ????? b/c i can not seem to find a please to download it right off of 50hz tone
and do i test at the speaker terminals of the amp and do i have to have the subwoofers hooked up????
put the vol at 3/4 of the way up and turn the bass knob all the way up on the dash?????
