96 Blazer walled..triple alt work
I just ran mine on top of the cross members then when I got to the exhaust I ran it on top of the frame to the holes that I made for them to come up and through
08 Ford F150
Yeah that would be a lot easier, but I'm going to get it fixed eventually
Need to see where I'm going to run it in the back....can't go outside the frame rail, inside looks close to the exhaust by the rear body mount
I have a spot cut for it to come back up in the right rear
I was gonna go OUTSIDE the passenger frame rail. Are you not for some specific reason im not getting bro?
You have a build log? or could you please get me a pic of how/where you ran your cables? I have the same year.
Im doing just 1neg and 2 charge lines is all...... Thanks for any input...
You can go outside or on top of the frame rail until you get toward the back by the tire, than you have to go inside and do something with it
Would be close to the tire, unless i'm missing something
Team Flex Issues
Ok, got the wires all ran and tied up. Got the pics the best I could, but they got kinda dark toward the end when I was underneath it
Dropping down
Behind the front wheel, tied up off the a-arm as best as I could
Behind the first mount
Keeps going and then around the 2nd mount
Goes a little further than to the inside of the frame
There's a 3rd body mount here by where the stock exhaust bends up. I ran 3 runs behind it, and the other 3 I ran on the outside and tied up away from the exhaust the best that I could
Back across the frame to the hole I cut
Team Flex Issues
