96 Blazer walled..triple alt work
Went to O'reillys and got a gates belt...turned out to be too small, guess I'll try the next size up
Need it playing by the 20th so the door panels are going on unfinished. Got one on and all wired up
Mids and tweeter amp wired up....it looks a mess but i'll get cleaned up and covered once the 5500's go in
Team Flex Issues
The mids sound good, tweeters are meh...maybe i'm just not used to the pro audio sound but they got harsh and bright when I turned it up
They have an inline cap on them from AQ and i'm not sure what it crosses it at, but on the hu I set the tweeters at 4k and 12db slope
Maybe I just need to mess with them some more
Team Flex Issues
Just looked...the belt I have is 96-1/8
The tensioner is maxed out and the belt is rubbing on the tensioner itself....didn't even start it, seemed way too tight lol
The 55's will be laying flat across the top of the batteries, stacked on top of each other
Team Flex Issues
U can get a smaller idler pulley
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
They didn't have a size in between the stock and the one that was too small in the gates...gonna try a different brand and see what they have, maybe the Goodyear
If not I'll try the smaller one with a smaller idler pulley
Team Flex Issues
