I just got my new DD-1 and I have to admit, I'm a total noob with it.
I'll give you my setup so you have all the info for my question.
I have a Kenwood DNX890HD head unit that goes to a JBL MS-8 signal processor which goes to a JL Audio HD900/5 amp.
Now, I "think" I understand how to set the HU and amp, with emphasis on the word, think. But how do I set the gain with the JBL MS-8? I know you have to gain set every component in line from the HU to the amp. I saw the video on setting gains on a line driver, but that is different from a MS-8.
Any help would be appreciated. Thanks.
Ms8 is a max output voltage of 2.8v
So set h/u with dd1 then do the jbl setup then sent the amps gain do jbl setup again to make sure
And set gains one more time for adjustment
That's how I would do it
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
-0db tone on HU. Then -0db tone on processor. Then whatever track you need for the sub amp
So I would set the HU with the DD-1.
Then do a MS-8 system setup without the gains set on the amp yet.
Then I would set the gains on the amp with the DD-1.
Do another MS-8 system setup.
Then use the DD-1 to set the gains on the HU and amp again?
Is that right?
Ok, so I use the -0db tone for HU, but how do I use it on the MS-8? It has no gain knobs or anything.
The ms8 will basically do its own setup
So u just have it do its thing then set the gain on the amp do it again so it gets the right measurements then set gain again
SCSB
Build logs:
Ok, I think I get it. So once again I just do this?
I set the HU with the DD-1.
Then use the DD-1 to set the gains on the HU and amp again one last time?
I have one more question. On the instructions of the DD-1 it says to turn the gains all the way down and the crossovers all the way up in order to perform the gain settings. If I'm using the MS-8, do I just disable the crossovers on the amp since the MS-8 will be handling that job, or do I still enable the crossovers on the amp and proceed the way the instructions said to?
Thanks for this help guys!
Edited by _Nomad_
For my 3Sixty, I turned off all xovers.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
