_Nomad_ Posted May 20, 2013 Report Share Posted May 20, 2013 I just got my new DD-1 and I have to admit, I'm a total noob with it.I'll give you my setup so you have all the info for my question.I have a Kenwood DNX890HD head unit that goes to a JBL MS-8 signal processor which goes to a JL Audio HD900/5 amp.Now, I "think" I understand how to set the HU and amp, with emphasis on the word, think. But how do I set the gain with the JBL MS-8? I know you have to gain set every component in line from the HU to the amp. I saw the video on setting gains on a line driver, but that is different from a MS-8.Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
CortezDTV Posted May 20, 2013 Report Share Posted May 20, 2013 Ms8 is a max output voltage of 2.8v So set h/u with dd1 then do the jbl setup then sent the amps gain do jbl setup again to make sure And set gains one more time for adjustment That's how I would do it Quote SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/ Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 20, 2013 Report Share Posted May 20, 2013 -0db tone on HU. Then -0db tone on processor. Then whatever track you need for the sub amp Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
_Nomad_ Posted May 20, 2013 Author Report Share Posted May 20, 2013 Ms8 is a max output voltage of 2.8v So set h/u with dd1 then do the jbl setup then sent the amps gain do jbl setup again to make sure And set gains one more time for adjustment That's how I would do it So I would set the HU with the DD-1. Then do a MS-8 system setup without the gains set on the amp yet. Then I would set the gains on the amp with the DD-1. Do another MS-8 system setup. Then use the DD-1 to set the gains on the HU and amp again? Is that right? Quote Link to comment Share on other sites More sharing options...
_Nomad_ Posted May 20, 2013 Author Report Share Posted May 20, 2013 -0db tone on HU. Then -0db tone on processor. Then whatever track you need for the sub amp Ok, so I use the -0db tone for HU, but how do I use it on the MS-8? It has no gain knobs or anything. See, I told ya I was a noob. Quote Link to comment Share on other sites More sharing options...
CortezDTV Posted May 20, 2013 Report Share Posted May 20, 2013 The ms8 will basically do its own setup So u just have it do its thing then set the gain on the amp do it again so it gets the right measurements then set gain again Quote SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/ Link to comment Share on other sites More sharing options...
_Nomad_ Posted May 20, 2013 Author Report Share Posted May 20, 2013 The ms8 will basically do its own setup So u just have it do its thing then set the gain on the amp do it again so it gets the right measurements then set gain again Ok, I think I get it. So once again I just do this? I set the HU with the DD-1. Then do a MS-8 system setup without the gains set on the amp yet. Then I would set the gains on the amp with the DD-1. Do another MS-8 system setup. Then use the DD-1 to set the gains on the HU and amp again one last time? Quote Link to comment Share on other sites More sharing options...
CortezDTV Posted May 20, 2013 Report Share Posted May 20, 2013 Ya That is probably the right way Quote SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/ Link to comment Share on other sites More sharing options...
_Nomad_ Posted May 21, 2013 Author Report Share Posted May 21, 2013 (edited) I have one more question. On the instructions of the DD-1 it says to turn the gains all the way down and the crossovers all the way up in order to perform the gain settings. If I'm using the MS-8, do I just disable the crossovers on the amp since the MS-8 will be handling that job, or do I still enable the crossovers on the amp and proceed the way the instructions said to? Thanks for this help guys! Edited May 21, 2013 by _Nomad_ Quote Link to comment Share on other sites More sharing options...
hdorre Posted May 21, 2013 Report Share Posted May 21, 2013 (edited) For my 3Sixty, I turned off all xovers. Edited May 21, 2013 by hdorre Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
