Is300 battery help
Okay so I got the XS power app and it recommends a D2400 but people on another forum have been telling me that it won't fit with the posts? I really wanted to clear this up and find out what the best battery would be for my car under the hood.?? Would kinetik be better? Or maybe. Yellow top but I've also hear lots of bad things about the yellow tops, so maybe not those lol
2001 is300Headunit: JVC KD-X50BTHighs/Mids: StockHigh/Mids Amp: NASubwoofer: DC Audio LV4 12"Subwoofer Box: DLDesigns Box tuned to 32HzSubwoofer Amp: AQ 2200DElectrical: NA Performance:SRT Racing intake with ECUHKS Super Dragger 2BC Racing Coilovers
BC 264 stage 2 cams
full head build with BC Valves, Retainers, and springs
Dezod Green Race Header Comming soon/Thinking about<p>Electrical: XS power under the hood (Suggestions Welcome)​Performance: BC Cams,Cam gears, maybe GTE Swap down the lineMy YouTube Channel Subscribe and i'll return the favor!Xbox Live Team Website.My First Official Box Build.My FacebooK
Run out to your car with a tape measure and camera. Measure the length, width, and height of your battery. Then take some pictures of how it's positioned in the vehicle.
I can help you better once I get an idea of what everything looks like
Okay so here are the dems w11" d8" h9.5"
http://i1123.photobucket.com/albums/l555/kwag415/8D375BB9-9F6B-4BC4-8783-539E1E93E39B-2103-0000012B59FECC69.jpg
BC 264 stage 2 cams
Or find the vid of Meade upgrading his Battery on the IS F . I believe he also has a vid on the IS250.
pretty sure it's different
BC 264 stage 2 cams
A d2400 should fit right in. Just get some of the top-post adapters and you are set
http://www.sonicelectronix.com/item_38803_XS-Power-580.html
Maybe they got the long posts idk just wanted to clear that up thanks snowdrifter
BC 264 stage 2 cams
No first hand experience with XS..but you should be able to install batt posts that fit your connections... or just change your connector fittings to fit the posts. OR if you're really pressed about getting the batt.. buy an aftermarket battery tray that will fit the batt better. Unless you have space constraints.
How about putting a Higher voltage battery? Could I do that without any issues?
BC 264 stage 2 cams
  • Who's Online   0 Members, 0 Anonymous, 748 Guests (See full list)
