Whatever floats your boat Lol. And aero's generally take up less box volume than slot port. Require less port area per foot to get the same job done, and are a lot easier to let you change tuning if need be. But they can be expensive. Two 6" aero's costed me $80.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
i used a 10 inch sonotube for my box tuned to 33hz and it kills the lows.... digs into the low 20s. im on low power (under 1k) on 4 10"s @ .5 ohm
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
First time using Torres box calc.
Would either of these work?
Sub displacement is wrong on this one
1992 Honda Civic CX Hatchback
K24a2 Swap
I want start on the box in the morning. I just need to know if one of these will work or if it needs to be changed.
K24a2 Swap
Usually when dealing with low power, you mainly focus on efficiency. The ivx's do great on low power.
You need more port on both, shoot for at least 12 per.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
The actual port length is going to be 18.25, where it says Physical Port Length.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
  • Who's Online   0 Members, 0 Anonymous, 584 Guests (See full list)
