Dwn4BassAlan Posted January 21, 2014 Author Report Posted January 21, 2014 okokokokokokokokokokokok I'm finally back on vyvanse after the weirdest month of my life. Not gonna bore you with all the details, but just know everything was stupid and annoying. But, now that the semester started I have some sense of drive to do stuff again lol. Here's what I need one more time, in great detail, explain the glue process for the spiders and coil and the soft parts. At this point I know how to do it, even fairly well, but there's no point in being as careful as possible now. -As an update on the thing overall: I was thinking about ways to space the top plate and basket so the coil would sit in a better position, and unless I get one custom machined I think I'm gonna go with one from sundown hopefully. In case that doesn't work out I'm open to ideas that could be done fairly easily. Maybe some aluminum square bars that I cut from one solid piece and drill through? But anything is appreciated. -Got the alt in as you know, but I'm waiting on the serp belt pulley to get here. Unfortunately, as always the chevelle broke with great timing, stuck in 1st gear, and I haven't been able to get it to the shop yet because I had no way to get there and back in time, and I still need to pick up my new BFG radials from Americas Tire. When I drop it off they should install all the new serp belt parts and get it going so that I can finally take the old box out and start wiring up for the new one. -And given what I have seen recently on the back and forth about whether it's best or not should I fuse the alt to batt run, should I go for it? I mean, from what I figured it can only help right? I guess my problem would be figuring out wire limitations. Anyone able to give me a rough estimate of the amp capacity of a 1/0 (skyhigh OFC) run from the alt to the battery if it would be ~2'ft ? I would need to find a 350a fuse too, since I only have 300a on hand. Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
STEvil Posted January 21, 2014 Report Posted January 21, 2014 You need to calculate the place where you want the coil to sit in the gap (centered, overhung, underhung) when at rest then build the spacer to that height. To attach cone & coil: (Protip: dry fit everything first!) -Slide spiders over coil. -Slide coil into gap to depth required. -Place shims iniside coil against pole to hold coil away from pole, centered in gap.-Slide first spider down to appropriate level then glue the triple joint thoroughly -Glue Outer ring of spider -Repeat for other spiders -Glue Surround -Remove shims from coil -Glue dust cap I thin thats everything, have a heck of a headache so its a bit hard to think right now. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Unkown107 Posted January 21, 2014 Report Posted January 21, 2014 fuck now i want to try this i got a pa mofo 15 d2 an a kicker solo l5 d2 where can i buy a basket for a 18 or bigger
Dwn4BassAlan Posted January 22, 2014 Author Report Posted January 22, 2014 which amp do you plan on putting on this monster for in vehicle testing? I have 2 mtx 1000.1s in there right now, but it should be no problem to have the 3.5k in pretty soon. You need to calculate the place where you want the coil to sit in the gap (centered, overhung, underhung) when at rest then build the spacer to that height. To attach cone & coil: (Protip: dry fit everything first!) -Slide spiders over coil. -Slide coil into gap to depth required. -Place shims iniside coil against pole to hold coil away from pole, centered in gap. -Slide first spider down to appropriate level then glue the triple joint thoroughly -Glue Outer ring of spider -Repeat for other spiders -Glue Surround -Remove shims from coil -Glue dust cap I thin thats everything, have a heck of a headache so its a bit hard to think right now. For the cone, my basket didn't come with anything besides that soft rubber surround, does the lip of the cone get glued directly onto the metal of the basket, or am I missing a thin plastic gasket ring? I've seen that piece alot and wasn't sure.. Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
fox_racin4 Posted January 22, 2014 Report Posted January 22, 2014 Youve built a motor, and cant figure out how to glue the surround down!?!? Youtube it. Its all over 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Dwn4BassAlan Posted January 22, 2014 Author Report Posted January 22, 2014 Youve built a motor, and cant figure out how to glue the surround down!?!? Youtube it. Its all over Lol I SAID that I already knew how to do it, but it can't hurt to be 100% sure or hear any advice that people have found to be particularly helpful when doing so. Maybe you remember the difficulties I had at most other steps while building the motor hahaha, I'm not trying to keep that up. Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
STEvil Posted January 22, 2014 Report Posted January 22, 2014 which amp do you plan on putting on this monster for in vehicle testing? I have 2 mtx 1000.1s in there right now, but it should be no problem to have the 3.5k in pretty soon. You need to calculate the place where you want the coil to sit in the gap (centered, overhung, underhung) when at rest then build the spacer to that height. To attach cone & coil: (Protip: dry fit everything first!) -Slide spiders over coil. -Slide coil into gap to depth required. -Place shims iniside coil against pole to hold coil away from pole, centered in gap. -Slide first spider down to appropriate level then glue the triple joint thoroughly -Glue Outer ring of spider -Repeat for other spiders -Glue Surround -Remove shims from coil -Glue dust cap I thin thats everything, have a heck of a headache so its a bit hard to think right now. For the cone, my basket didn't come with anything besides that soft rubber surround, does the lip of the cone get glued directly onto the metal of the basket, or am I missing a thin plastic gasket ring? I've seen that piece alot and wasn't sure.. i've never glued to anything but the basket. If there's any other parts they usually sit on top of the lip to make it look clean or under the basket to help seal against the wood MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
SICKSPD Posted January 23, 2014 Report Posted January 23, 2014 so what will be the manufacturer recommended enclosure specs for this thing 09 Challenger R/T (Audio system under construction): Pioneer AVH-X4500BT (PAC RP4CH11 harness) (2) Sundown Audio SA-8v2 (inverted) CT Sounds AT1400.1D XS Power D3400 40 sq ft. Audiotechnix deadener 1/0 Audiotechnix wiring stock Boston Acoustic 7 speaker amplified system (for now) Sealed trunk enclosure Build log: http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/ TEAM GOAT
Dwn4BassAlan Posted January 23, 2014 Author Report Posted January 23, 2014 so what will be the manufacturer recommended enclosure specs for this thing Braced as a motherfucker. Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620 Fucking love Alan you goddamned fucking super nerd lol When Alan uses big words I don't understand It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room. I missed Alan. RIP 5/29/15 - I love you son.
fox_racin4 Posted January 23, 2014 Report Posted January 23, 2014 pics of what you want to glue but dont know how 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
