Xplay75 Posted May 26, 2013 Report Share Posted May 26, 2013 I have a rf 1500bdcp with a birthsheet of 19879 and was wondering what brand and size subs would like the amp thanks Link to comment Share on other sites More sharing options...
Integra_boomer Posted May 26, 2013 Report Share Posted May 26, 2013 As for brand there is no certain "brand" that will work best. Its all on applocation and your goals. Nice amp there. Il say find a sub manufacturer you might like and get the subs with the right impedence. For ex if your going with 2 subs youll want Dual 1s or dual 4s to get that 1 ohm load. (I know the CP version is suppose to do the same rms @ 2ohms as well.) if your going with one sub make it a Dual 2 so u can wire to 1 ohm. The math is pretty simple once you learn and match up your power rating of course. If youre going with one sub it better have alot of power handling 1500~rms range. With the two subs you could spread the power out more. Ex. With two 1000w subs you would have plenty of handling, cooling bc theres two coils to divide the power and heat, and louder imo more cone area and again two coils. 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s Link to comment Share on other sites More sharing options...
