use this as a Guide for these subs..
10s : 1.25 - 2 cubes ported
12s : 2 - 3 cubes ported
15s : 3 - 4.5 cubes ported
18s : 4 - 6 cubes ported
At higher power err towards smaller; around rated power err towards bigger.
No... Use manufacture's specifications as a guide.
Krakin's Home Dipole Project
Well they don't have the specs out yet...and I will have a Singer 250A with his overdrive pulley with a Redtop under the hood and probably two runs knu cca to a khc800 in the trunk, plus the big 3 of course. Singer said that his 250A is ideal for 4-5kw systems and he's credible. Does all that sound good to you guys? I don't want overkill so I don't need an XS3100. :P
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
im sorry but you gonna need a bigger or another alternator bcuz the saz3500 amp needs 350a..
Vehicle: 2005 Kia Sorrento Ex
Head Unit: Samsung Galaxy Note 10.1
Mids & Highs: Motorola KSN-1005s & Alpine SPR-17C Type R 6.5s
Speaker Amp: Sony XM-ZR1252
Sub Amplifier: Pure Audio 3000.1
Subwoofer: Incriminator Audio Death Penalty 21"
this is so wrong lol
look at Fi Q an 18 needs 6 - 8 cubs ported and not the 4 -6 you stated.. every sub is different and you should go with manufacturer recommendation
i wrote these subs,,,
I would recommend doing the math on what the amp will be drawing at it's Ohm load. Then seeing how much much current is possible to transfer through CCA or OFC, cause I don't remember them right now, to see what runs you need to do.
And MOST importantly get a reliable volt meter. I suggest buying a SMD VM-1 especially with the discounts going on for it right now. SMD coupon i think is $10 off, and sending in you old - broken or working - volt meter gets you $25 off each one sent in.
Those recommendations are straight from Jacob's mouth which if you do not know that is the owner of Sundown...so yes that is the manufacures specifications...now please shut up....
N9neMillahhh - 4 cubes will be perfect for the two 10's on a 3500Dv2 at 1 ohm; don't listen to Krakin because he obviously has no idea what he is talking about....
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
Although it is nice to see you want to help Felton .... stop giving bad advice, without seeing the "EXACT" requirement for the Z.4 I wouldn't go beyond 1.5 cubes per 10" because that would be kinda ridiculous .... Please read up some more before someone listens and loses a subwoofer or more.... I mean this with respect....
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
I haven't seen that posted by Jacob ... unless I missed it someone ... Can you provide a link?
And another subwoofer guru!!!!
153 at 23hz
thank you.. someone here as been reading the forums..
  • Who's Online   1 Member, 0 Anonymous, 500 Guests (See full list)
