Massive Audio D8000 undressed
banginhummer
im using 6 of these in my car :)
yes it uses the same board as SPL dynamics ice 3500 and soundmagus VS3500. we tested them all in 1 car.
http://www.talkaudio.co.uk/ipb/index.php/topic/357473-spl-dynamics-ice3500-vs-massive-audio-d8000-vs-soundmagus-vs3500/page-2?hl=%2Bsoundmagus#entry4145769
Massive and soudmagus have a tie first place. spl dynamics did less power.
massive is stronger build because the board is shoven into the chassis so it is tightened all around.
we had a few soundmagus amps defective(we had 10) because of shaking, nog big deal just the block that holds the board was vibrated away so the board had no support and a few mosfets come off, replaced them and secured the board better and it was ok.
Also the massive audio are a lot smaller then the soundmagus, its a pre... but also a con because of the heat.
http://www.youtube.com/watch?v=h8g8w1JI3XI
Amp does rated power at .5, does get hot, but never turned off into protect. I personally own this amp, and its very impressive considering I've used sundown, and dc. This amp actually puts out more power than the sundown 3500 did. Not saying its better, just put out more power in my setup.
I like their micro technology, like how soundigital is starting to do.
Enjoy the pics.
the Second last pic ( sorry for bluryness ) notice the similarites
Camera
C6603
Focal Length
4.1mm
Aperture
f/2.4
Exposure
1/32s
ISO
80
and theres alot of differences there too.
Owner of BigAss Ports
if you're located in houston, or close to houston, I can personally bring you to the shop I get mine from. $500 brand new
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
  • 3 weeks later...
  • 2 years later...
  • Who's Online   1 Member, 0 Anonymous, 737 Guests (See full list)
