I am looking to add get either the SA15 or the e15 but I was wondering what the difference between the two are. I am limited on space because I drive a small suv(Toyota rav4) I am debating on getting 2 e15s and inverting them or just get 1sa15. What are your opinions on the 2 and best way to mount them. Thanks for the help!
SA has a stronger motor, more excursion, and more thermal handling.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
would i be better off with 1 sa-15 running 800 watts or use 2 e-15 1000 watts? i would love to do 2 sa-15s but i dont think my car will be able to power it without a big 3 upgrade.
Just FYI you need to do a big 3 upgrade anyway. No matter what size amp you get you need to do it. It's no big deal though. Just 3 wires.
An SA will want more than 800 watts plus 2 e15s is 2x cone area and more than likely at least the same or stronger motor force combined than the single sa.
Go with the 2 e15s if you can fit them in proper sized box (6 cubes net minimum for the pair).
here is what i have to work with
the dimensions i have to work with are:
32w
20d
20h
the box was going to be
4.02 cubes
32w
18d
18h
with the port going accross the bottom tuned to 34hz
unless i take the backseats out there is no way i can get 6 cubes unless i take the back seats out.
would it work well if i inverted the subs and put it on the top of the box? i just dont want to waste time or money building a couple boxes
Yeah dude you are limited to a single 15 or a pair of 12s with that space.
I'd to a pair of 12s if you can
Cone Area
One 15" = 176.71
Two 12" = 226.19
Box Volume
1 E15 = 3-4 ft^3
1 Sa15 = 3-4 ft^3
2 Sa12 = 3-4 ft^3
Those box specs are from sundown
just somthin to think about ... if it were my vehicle id go with 2 12s. Are you set on a 15?
Edited by TrunkMuzik
Without music, life would be an error
Cone Area
One 15" = 176.71
Two 12" = 226.19
Box Volume
1 E15 = 3-4 ft^3
1 Sa15 = 3-4 ft^3
2 Sa12 = 3-4 ft^3
No I'm not set on a 15, I was trying to design a box that could fit 2 12s and it is a tight squeeze. I just am worried my car won't be able to handle all the power is give it if I went with the sa12s. I'm not worried if I do the e series but I want the sa series. I really appreciate all the help from everyone! I am trying to learn about car audio. I thought I was making a good buy when I got the sound ordnance bp-80? At this point I think anything will be better than that.
One more question for you guys. If I build the box subs up port back is that going to be good. I read that to get the lower frequencies the subs should be mounted vertical.
  • Who's Online   0 Members, 0 Anonymous, 1594 Guests (See full list)
