this is my setup
24xi2yc.jpgbr>
and this is the settings on my bass amp
my problem is that the fuses keep blowin on the bass amp (i have 2 80a fuses on the amp), so wht kinda dist block should i go with? is my amp set right?
thanx in advance!!!
2006 Altima 2.5
Alpine Iva- w200 Head unit
2 L7 kicker 12s in a slot ported box tuned to 38 Hz
Rf T10001 @ 1 ohm
Rf P4004 @ 4 ohms
Poineer TS-D161R 6.5" in door panels
Pioneer TS-D690R 6" x 9" in rear
stinger 1/0 wiring
are u blowing the fuses in the distro block or the fuse on the actual amp? how much total fusing is in the distro block? how much fusing is physically on each amp?
i likes me some audio stuff...
im blowin the fuses on the distr block... i have 3 total fuses... 1-60A to my highs amp and 2- 80A fuses to the bass amp. the fuses on each amp are perfectly fine
2006 Altima 2.5
Rf T10001 @ 1 ohm
Rf P4004 @ 4 ohms
stinger 1/0 wiring
huh...then i dont know why you would be blowing fuses in the distro block b/c it looks like its setup fine to me....unless the fuse on your amp is rated higher than 160amps...which i doubt...idk...
the fuse on the amp is 150A... the 2 glass fuses always burn right dwn the middle... do u think i have to change my dist block? and if i do will i need another in line fuse 4 it?
2006 Altima 2.5
Rf T10001 @ 1 ohm
Rf P4004 @ 4 ohms
stinger 1/0 wiring
i would try just running one power wire off one fuse that has the same or a 10 amp higher rating then the fuse on your amp.
Edited by Clif
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
that was tha problem the biggest glass fuse they make is 80A, i need 150 for my amp... i was gon get a fuseless dist block, but the dude at the sound shop said i would need another in- line fuse holder
2006 Altima 2.5
Rf T10001 @ 1 ohm
Rf P4004 @ 4 ohms
stinger 1/0 wiring
the other fuse is 60 amps...
2006 Altima 2.5
Rf T10001 @ 1 ohm
Rf P4004 @ 4 ohms
stinger 1/0 wiring
i would just avoid the fuses all together and run a 4 gauge straight off of the side of that distro. also you might be blowing them because of your choice of wire size all together. small wire =resistance=heat=burning up fuses. you might want to jump up your power line from the battery atleast to 2 gauge.
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
  • Who's Online   0 Members, 0 Anonymous, 826 Guests (See full list)
