some help or advice wanted.
KiKaZz74
Alright. That sound simple enough. And then how do I attatch them to my hu? Any xovers? Or attatch them to the front speakers since my hu is a bitch to pull out. And would those RE tweets work?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Yes, your REs should work fine if they have their own passive crossovers with them. If not, find you some that have them ...
and yes, you can just attatch them to your front speakers for now ...
Alright. I was thinking the ones sierra was talking about. Ill have to see if they have some or not. If they don't I gotta find some? Or would a bass blocker work?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Tweeters should not play anything below 2000 htz ...
http://www.sonicelectronix.com/item_68026_RE-Audio-TW-20.html
Those have the crossovers. So will they work? And just wire them into my speakers and put them in the a pillars? Or what are the sail panels? Sorry I'm still a noob to all this.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
I can not recommend name brands because I'm sponsored by Blues Car Audio ... but Yes, those look fine.
Sail pannels are those small pannels on top of your door pannels near the A- pillars ...
Ok I inderstand. And thank you. Id rather do pillers cuz I have a smooth one on passenger but a hump on driver for like a power mirror. I think ill pick them up then. Could I use the stud on the back of it or remove it and do threaded rod the whole way? They will eventually get molded into place down the road once I can upgrade everything.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
I say use the threaded rod so you can bend it and angle your tweeter fairly easy ... Just the 45 degree bend and aiming the tweeter the way I posted earlier will give you a better musical presence ...
Alright. Thank you very much for your help. Im guessing itll wire down to 8ohm? 2 4ohms at 2 or 8ohm at the HU
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Ok should be good to go this next week. Im buying some rf silk tweets and xover from keep_hope_alive which is the basically family member that got me going. We are going to work this next week on everything hopefully.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • Who's Online   0 Members, 0 Anonymous, 1302 Guests (See full list)
