djscrappydee Posted June 11, 2013 Report Posted June 11, 2013 what does the does the canceller option when you buy hids for? (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
From_the_Valley Posted June 11, 2013 Report Posted June 11, 2013 I'm pretty sure it's to eliminate error messages from the computer on certain cars. The canceller is suppose to trick the computer into thinking the stick bulb is there. Hope that helps
kickass audio Posted June 12, 2013 Report Posted June 12, 2013 ^^like he said. It prevents newer cars from showing the message that your .... bulb is blown. All it works as is a resistor that tricks your cars computer into thinking that the old halogen bulb is still installed. Halogen bulbs have a different resistance than HID bulbs and your computer will think a HID is an broken bulb because it looks at it as if its an open circuit. You don't need those if you have older vehicles that don't have the bulb out detection or if you can just deal with it saying the bulb is out on the dash. To see if your car really has that blown bulb detection feature take one of your headlights and disconnect the light from the socket. If nothing comes on in the dash to indicate the bulb as being blown then you don't have blown bulb detection and can just forget about getting that canceler option. If it does show a message that that bulb you pulled is blown then you need the canceler option. Also as a friendly reminder, don't forget a relay harness. Dont risk burning your stock wiring with a HID. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Carbon Posted June 14, 2013 Report Posted June 14, 2013 what does the does the canceller option when you buy hids for? No dummy light...
