SnowDrifter Posted June 14, 2013 Report Share Posted June 14, 2013 Upload to youtube, post the link here ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Mario928 Posted June 14, 2013 Report Share Posted June 14, 2013 99.9% of the time is user error. It could be your dd-1 is defected ort you are probably doing something wrong. Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
Sky Posted June 14, 2013 Author Report Share Posted June 14, 2013 Im just going to send it back and get new one. Now when I turn the dd1 on the 40hz and 1khz just turn on even when it's not plugged into anything. I think I got a defect 99 F-150 Build Log Link to comment Share on other sites More sharing options...
Sky Posted June 14, 2013 Author Report Share Posted June 14, 2013 I've been messing with it all day. Went by the manual/YouTube videos and yet no luck it's not operating like I've seen it to be 99 F-150 Build Log Link to comment Share on other sites More sharing options...
southern66ss Posted June 14, 2013 Report Share Posted June 14, 2013 didn't think you were supposed to hook the red + lead to anything other than the + signal coming from the amp. or in the head unit case just unplug the rca to the amp and plug it directly into the DD-1 at the top. More than likely when you touched the + signal input wire to the power/remote wire it might have shorted something out in it. talk to steve and see what he thinks can be done. 2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp RE Audio SEX 12D4 Subs (12") Hifonics Brutus BRZ1200.1D NVX 4 gauge wiring NVX Deadner XS Power D925 Big 3 1/0 ga Q Power wire Custom box by Pro Audio Gulfport, MS 137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up Link to comment Share on other sites More sharing options...
Sky Posted June 14, 2013 Author Report Share Posted June 14, 2013 You that might be the case. I accidentally did that at first and touched the remote and it seems like it's all gone down hill since then. Now it won't even show when it's distorting. Doing it thru the RCA into the dd1 doesn't give me any sort of signal at all 99 F-150 Build Log Link to comment Share on other sites More sharing options...
southern66ss Posted June 14, 2013 Report Share Posted June 14, 2013 sounds like it cooked it bro. Shoot Steve and email, he might be able to help you with it. 2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp RE Audio SEX 12D4 Subs (12") Hifonics Brutus BRZ1200.1D NVX 4 gauge wiring NVX Deadner XS Power D925 Big 3 1/0 ga Q Power wire Custom box by Pro Audio Gulfport, MS 137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up Link to comment Share on other sites More sharing options...
Austin Willert Posted June 6, 2014 Report Share Posted June 6, 2014 having the same problem right now, i have done everything even turned the gain up a little, and still nothing anyone figure anything out on this? on mine the power is the only thing that will light up, when i turn it on i see the distortion for a sec and then its just power, i try to do the head unit volume test, hook the dd-1 to the speaker terminals on the amp, and get nothing. Link to comment Share on other sites More sharing options...
