new HO Alt question
I just had my new 270xp put in my 2001 4runner and my voltage is lower than my stock alt. I have left OEM wiring and added 1/0 with 300A fuse to (+), added 1/0 from alt mounting bolt to vehicle frame (ground down), added (-) to frame (same bolt as alt ground), (-) to chassis, Only wire I did not upgrade was from the fuse box under hood to (+) but I dont see how this would be the issue.
My stock alt would start up at 14.2-14.4V and driving I would get 13.2-14.0V depending. Now I start up at 13.7 and drive at 13.5 but fluctuate from 13.3-13.8.
I have checked the battery while off and it is at 13.06V (Stinger SPV69c). What did I not do correctly or do I need to bypass something on this vehicle. Thanks in advance!
Guest DC Power Kyle
The newer Toyota Denso regulators are a little sensitive. You may have a lower voltage at start up sometimes. What do you drop to with your stereo at full tilt?
Guest DC Power Kyle
That's about right in spec on a Toyota regulator. I see 12.8-13.2 depending on weather.
so I shouldnt worry then? but how would my stock put out 14.2-14.4 at startup and 14.0 on the highway? Everything Ive seen shows that on start-up, my voltage should be 14.2-15.0 . I honestly thought by installing this, I would NOT see a voltage drop below 14.4 while driving
Sometomes the stock regulator doesn't work rifht with higher output alt. Could consider getting an external regulator
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
how much power are you pushing audio wise?
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
Guest DC Power Kyle
John since I'm at slamology I don't have access to the proper stuff nor a reliable Internet connection. Give me a call on Monday and I'll talk with you.
I was wondering if there was something forcing it to this voltage.
I have my T1500-1 @ 2ohms pushing 2 Alpine 12D2's and my mids/highs are on Kenwood X450-4 @ 4ohm. So a little over 2000 continuous.
Ok, Thanks Kyle. Hope you have a real good time! anyone gonna be putting up some pics from this event?
Guest DC Power Kyle
I have my DSLR and our camera. I'll have tons of videos.. I brought two 64 gig SD cards just for the video camera.. now lets see if i can use it all. LOL.
  • Who's Online   0 Members, 0 Anonymous, 1710 Guests (See full list)
