1989 mustang gt clutch cable adjustment
anyone have any idea ow to adjust the stock clutch cable. Its not fully disengaging the clutch.From the floor you have less than a half inch of upward travel before the clutch grabs. If you don't stand on the pedal and pin it to the floor it will not shit.
  • 3 weeks later...
Steeda makes some of the best clutch quadrant parts for stangs.A quick trick to try...usually works before it gets to the problem you are describing...but take your foot and put under the clutch pedal...pull it UP towards you...you may hear a click..then push it all the way back down. At times it helps to reset the pedal throw. But if the cable is stretched it only helps so much. Ive broken enough of those cables to want to go to a hydro setup.
2012 Toyota 4Runner Trail Edition-Singer 240A Alt, Odyssey Battery,Pioneer AVH-2550NEX head-unit, Pioneer GM-DX874 powering Kicker CSS67 front-CSC5 rear, and Memphis PR 1.1000 powering 12in SSA ICON in G.P. ported box.
2003 Tahoe-320A Alt, Odyssey Batt,2 Resilient Sounds Gold 15's sealed powered by Crescendo BC2000D, Turbulent Designs Ported box AVH601EX head unit and Pioneer 3ways in all doors.
