O-Scope help?
I have a portable o-scope that my grandpa gave me, and I have no idea how to use it or what settings to use...I just got my wisdom teeth out yesterday so I can't go out and see what the model is but it's a fluke handheld o-scope
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
  • 3 weeks later...
Any help? C'mon guys...please?
Sub Amps: SAZ3k
Well basically use it like any other oscilloscope, you take the probe (if you have one, you should) and simply plug in the postive and negative into the positive and negative on the amp (it doesnt really matter cause oscilloscope just lets you see the waveform. You can adjust the sensitivity on the oscilloscope to make the waveform "zoom in or out". once you have it hooked up, basically turn on the amp, play a test tone (60 hz -3db) and tune the amp till it starts to clip. clipping is where the peaks of the waveform arent a sin wave, where the peak should be round, it starts to flatten. keep the waveform full sin.
About using that direct model, it shouldnt be any harder. all oscilloscopes are pretty much the same. They serve the same service.
Bout to put in 2 21" Wardens on a taramps 8K
well, not much we can help you with until we get a pic. Using one is actually very straight forward, but a specific application you want to use it for would help us help you as well.
A pic or model number would be helpful so we know what we're dealing with.
First off, without knowing that, look at the o-scope and find its input voltage rating.
You'll want to make sure that you aren't over-driving the input to the o-scope.
Smaller and cheaper o-scopes may have smaller voltage tolerances so you want to make sure that you aren't damaging the scope with what you're measuring.
After that you have basically two settings:
1.) Vertical voltage setting (V / DIV)
2.) Horizontal time setting. (t / DIV)
It helps to know what signal you're looking at so you can approximate the settings and "find" your signal and then fine tune it.
Some o-scopes have an auto-setup feature which is also very handy. You simply connect the signal and press the auto button and the scope sets itself up based on what it thinks are the best setting(s).
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
I'll post pics of it in a bit. It a fluke scopemeter, model is the 123 industrial, gimme a bit fellas.
Sub Amps: SAZ3k
If you need basic operating instructions for your scope try Google search put in the make and model no. and you should find something .
YouTube should give you a basic understanding of what to use a scope for if you search how to use an oscilloscope . With a little understanding you'll soon be scoping all sorts of waveforms .
I've tried...it's a pretty high tech. I'll post up the pics now just let me get through photobucket quick...
Sub Amps: SAZ3k
Here's a link of the fluke site, they call it the 120 series.
http://www.fluke.com/fluke/usen/portable-oscilloscopes/fluke-120.htm?PID=55999
Sub Amps: SAZ3k
I've tried every setting and can't seem to get it right...there are like 3+ settings that you can set up the probes with...and it's the $1,500 model, my grandpa works for a pipeline company and got a new one so he gave it to me..
Sub Amps: SAZ3k
  • Who's Online   0 Members, 0 Anonymous, 1365 Guests (See full list)
