4bent's loud blowthrough glassed doors on pg 6
True but a bigger chamber will have unloading issues compared to a smaller one weather it be sealed/ported/4th/6th/8th/ABC/whatever.
With 4 orders you have an advantage tho of being able to control the amount of cone movement with the size of the sealed section,
In 4ths a bigger sealed will get lower, and big ratio is more efficient
Big ratio has narrower bandwidth though, so it's a tricky compromise :)
narrow bandwidth you say ;)
not sure what exactly makes this system tick but I believe it has something to do with 1/4 wave? something that I don't understand whatsoever, BUT I believe this is a 3:1 or 4:1 ratio 4th and it does 61-62's iirc. Just 4 15's, one of the most impressive setups i've seen.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
I think u should try a 4th order V shape subs in the far back , 3 cubes sealed per side and 10 ported, 200" of port ish
I have 220" for 2 15s and wish I could get more...
HxWxL
17.5x49x72
best i could remember without the actual paper we drew it up on
Blowthrough
Subs
rebuild
Amps
1-SAZ3500
1-T4004
Coaxial
1Set Alpine Type-R Components
1 Set- kicker ks 5.2
1 Set- Kicker ks 6x8
Reciever
Pioneer DEH-P7400HD
2000 Ford F-150 EXT Cab
Clarion EQ
am i missing something here you guys?
im sure your probably missing a bunch of shit. just the first one that comes to mind is that you have to understand how to manipulate the enclosure to get the needed amount of back pressure on the subs to help them under control at your power level, but not kill the efficiency or the cooling. second is that you have to understand how the actual physical depth of the enclosure affects the wavelength of the enclosure and therefore its tuning. you have to also understand the wavelength between the enclosure and the front of the vehicle, and how that affects the cabin resonance and the relation of that to the enclosure tuning.
there is a lot more shit that we could talk about as well, but by looking at what program you design with, there is no sense in wasting my time getting in to it.
Owner of BigAss Ports
Please stop with the 6th orders!
4th order all day, no ofence but you don't have the knowledge or skill to build a proper 6th orders, without proper plotting you are just guessing and it's all trial and error, so you would need to be able to shrink and change port easily if you go that route, which can not be done that easily in a box like yours
I really recommend a 4th order,
But either way the hole in the back of your cab is not big enough, you need like everyone said 200" of port or more, up to 400" ish for big enclosures
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
im trying to get some help here.. from tuning the box low in the rear do you think i can extend them to tune higher i will get better results?
before i move onto building a new enclosure.. i will take in consideration your idea for a 4th. if you can help me out with it ide really appreciate it
Blowthrough
Subs
rebuild
Amps
1-SAZ3500
1-T4004
Coaxial
Reciever
Pioneer DEH-P7400HD
Clarion EQ
Either way you would need way more port area 200square inches or more (4th or 6th order)
Think 10x 20 Or 15x 20 for the Opening into the cabin, that will drastically help you
also then make the ports in the back smaller, about half the width in the back before they come together, once they are one port they can be your original width
All that if your really trying to keep a 6th order
SCSB
Build logs:
6460466C-212D-4BA0-8C61-2A8CCD385804-190
Really really quick sketch not to scale the two sealed outside chambers would be 3-4 cubic feet each, the middle section would be 7 to 12 cubic feet ported
Tune to 46 if u want the lows
SCSB
Build logs:
ok makes sense . this is my old 6th order. tuned this one high but played loud and low. let me give it another shot and i'll get back to you cortez
Blowthrough
Subs
rebuild
Amps
1-SAZ3500
1-T4004
Coaxial
Reciever
Pioneer DEH-P7400HD
Clarion EQ
See how ur port is small in the rear chamber^^^
And then massive front port, the rear chamber is tuned low with little port area per cube and the front chamber is typically bigger with a very high tuning and a massive port area
I would still do a 4th order I have seen the best results from 4ths from my paroozing,
There are a few like the audio innovations truck that are super loud with a 6th order but their builds and I can't stress enough how much they really know what yet are doing
SCSB
Build logs:
