Is everybody actually following the websites recommended .75 cu ft per sub ported?
just wondering what everyone is using with the sa8 v2 D2
going to order 2 of them and want to get them as loud as possible
any help would be awsome
Without music, life would be an error
I did. I put 8 of them in 6 cubes and they do just fine. They'll take dumb power, too.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
.75 would be awesome space wise as long as it will use the full potential of the subs...starting with 575rms each and will bump it up to 750 each soon after. aero ports? center? L port? any of them better then the other? going to have them blow through the back seat opening with the seats down
Aero's are hands down the most efficient of ports, but if designed properly, they'll all do the same thing.
Sub Amp: AB 450.1
XS D3100
Come on 150!
The motor force of those little things are plenty to keep them bangin in small boxes. Just about all sundown subs work well in smaller enclosures
Sub Amp: AB 450.1
XS D3100
Come on 150!
I tried to work out an enclosure with areoports bit the ports would have had to be long as fuck. I have a design for an "L" port box I am going to try next weekend...
for 2 8s?
Check out my sig, I did two in a 4th order :peepwall: but anyways yes .75 is the way to go. Do not skimp out on port area though. when its all said and done the box can be about 1.4 cubes gross for one but about 2.3 with two because of the port.
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
