Tahoe 2013/2014/2015 RF, FI, XS, SQ, TM, etc...
Also are you running a 3Sixty.3 or just using your HU for tuning? If you are using a .3 try bypassing it and go straight to amps with rca's...
not using a 3sixty at this point in time. It's all good bro.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
so did you get it fixed?
Honeslty? nah, took everything out except the HU and RCA's under carpet. When new HU comes I will redo entire thing piece by piece. RCA's behind head unit were electrical taped after connecting to eliminate grounding out etc. I have 3 runs to the back that I made sure were not pinched anywhere and swapping them around from amp to amp, removing all amps and rewiring speakers into different amps and RCA's etc. problem still existed so I'm confident it is the HU. Even swapped around power wire, eliminated all but 1 battery and simplified all electrical thinking that could be the cause if interference but still problem existed....basically the only common denominator (and the only thing left) is/was the HU so fuck it, took EVERYTHING out. Even undid grounds and will re-install one at a time. I'm not gonna fuck around chasing down an issue forever.
Oh-well gives me time to paint the box a little darker (subs are already pulled) maybe sand the port a little smoother, clean up the wires better etc. Ordered up a Crescendo BC5500 so i can run a solo sub amp, will prolly sell 1 T2500 but keep the other. I would love to go with 8 -15" and a DC 10k but it wont fit behind C-pillar and I need rear seating for my daughter (car seat). I have 3 other vehicles but nothing I want to stick large stereo in. Oh-well, decisions, decisions...
Plus If i were to wall it then i might actually have room for batteries since i have NONE as of right now. I would also like to add more batts.....
Will post up pics. when i get the stuff back in. It's super hot out here for a week+ so that gives me time for more stuff to arrive and do some thinking and planning and box some dry time. haha I should have bought a Suburban!!
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
The bc5500 should get nasty!
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
God I sure hope so (and expect it to)
4 - 15" subs rated at 1200 watts RMS x4 = 4800
Crescendo BC5500 @1 OHM = 5800 watts RMS
An extra 1000 watts RMS just for shitz and gigz = WWIIIIINN!!!!
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
i found that the issue with my noise was actually a ground to the chasis, it got corroded so bad that it still had contact but not as much as it needed when i pulled it out it literally broke in half. also i havnt tested it yet but i believe it made my dd1 not work correctly
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
i found that the issue with my noise was actually a ground to the chasis, it got corroded so bad that it still had contact but not as much as it needed when i pulled out it literally broke in half. also i havnt tested it yet but i believe it made my dd1 not work correctly
Thanks, will be checking EVERYTHING when re-installing but will definitely take note of grounds. =)
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
getting rid of the T2500's??? Mehhh.. I couldn't do it if I already had 2 of them,I like my bdcp too much to change for Crescendo.. And the DD-1 does have to have a good ground to work properly,I really like how they designed it so that it gets no interference while using it..
*thinking* about getting rid of 1, lol.
dd-1 good ground, wired straight to batt, lol 4 body grounds going straight to batt
oh well we'll see what the future holds, everything is up in the air for now...
if i had the room i would buy 8 15" and a 10k TODAY
but i have to settle with keeping my back seat for now. hehe
Wish i didnt have the issues, wish i had more time, wish i had an exact plan in play, i wish, i wish, i wish, lol FML
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
