Tahoe 2013/2014/2015 RF, FI, XS, SQ, TM, etc...
  • 3 weeks later...
My long slow build might take off again with some change ups. For those that use mobile and can't see my signature I will repost as my equipment list below.
Note that the only thing not here from this list is the subs
2007 Chevy Tahoe
1 XS Power D4800 (under hood)
1 XS Power D3400 (under hood)
2 XS Power D3100 (rear)
6 XS Power XP3000 (rear)
1 Mechman 370 amp Elite 6 Phase alt
2 DC Audio 5.0K amps (sold)
3 CT Sounds 60.4 amps
3 RF T2500-1bdCP @0.7 ohm (1 is spare)
8 Crescendo FT1 Supertweets w/crossovers
4 RF T3 6.5" mids (active)
2 FI SP4 15" subs
4 Crescendo CZ 6.5" mids (active)
8 RF P1T-S 1" tweets (active)
320+ Sq. Ft. Sound deadener
Pioneer AVH-X5500BHS (might change to Kenwood or Alpine)
LOTS ToolMaker goodness
Anyways, got these the other day, kind of like this design so I figure I will add it to my arsenal
The I got 5 sheets of 3/4" MDF board for new box and amp rack, Sold my Silverado so loaded them up in my Tahoe
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
I don't want to rehash to many old details but some old and new pics. of equipment for those that have never seen my log before
16 Ton
Only some of the TM goodies
Super tweets with crossovers
Battery bank for inside the vehicle
CT Sounds goodness
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Those terminals are sweet
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Go through build log to see the rest of the stuff I have had for a while that's on the list, lol. I got more stuff coming that is not on this list. I am keeping this build very simple, non-wall, just subs up and port back, box designed by CleanSierra here on the forum.
Today's agenda is that I might remove the XS Power D4800 and D3400 from under the hood and stick the 2 D3100's in there (they have been proven to fit in both locations with slight modification). Also, I am in the process of getting the DC Power dual alt kit because mine is PCM controlled and I hate hot charging under 14
Current set up as of today (also gonna clean some wiring up under there)
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Even consider using heat shields on your batteries? That might help the lower charging voltage, because I know that when the battery is hot the pcm drops the voltage.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Thanks for the tip, I'll look into it. But it just seems like even in that case thing (I have seen them and know what you're talking about) that in the hot summer it's still gonna be sweltering under the hood for hours on end with or without them?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Nice man lookin good can't wait to see how to fit the d3100's under there! Looking forward to more updates?
Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are!
I'm not compensating, just proud of fabricating!
My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts
http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19
Um, sure, lol. Ok, simplified the wiring some. Gonna have a second alt run the stereo that is not PCM controlled so the factory alt can go back into the stock location. Since that setup doesn't require anything special of a battery I put the D4800 over there as it's my smallest XS Power battery I have. On the other side of under the hood I will hook the second alt right onto the other under hood battery then use my runs to the back from there, thus 2 separate charging systems. Wasn't originally going to go that way but I think i will like it better. I have seen people stick a D3100 on the passenger side just have to move the coolant reservoir a little but I have no need for that anymore but I will have a D3100 on the other side which is nice because that side is much easier to fit one. Anyways, here are some updated pics. of the under hood progress today, only thing missing (apart from dual alt kit) is the cover for the fuse panel.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
That cleaned up nicely! Good work!
