Sky High Car Audio
im looking to get the 1/0 cca spool but came across a post stating the 1/0 lugs do not fit the 1/0 wire, that the 2/0 lugs would be needed. in this correct? just need to know so i can finish my order list. also, if the 1/0 is bigger than 1/0 wire, would i also need reducers on the amp?
I am interested in this response, too.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Im pretty sure thay sky high 1/0 lugs fit sky jighs 1/0 and sky highs 2/0 fits sky highs 2/0 i thinks its just other brands lugs that dont fit his 1/0
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
This 1/0 wire will fit into most amp terminals, and it will fit into dual inputs from PDB and TM, but it will need a 2/0 copper lug to fit the 1/0. And it will need a 4/0 Lug to fit the 2/0 from SHCA. you most likely will not need a reducer for the 1/0 unless its a cheap amp
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Edit his lugs will fit his wire 1/0 to 1/0 and 2/0 to 2/0. Any outside lug you need 2/0 for the 1/0 and you need 4/0 for the 2/0
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
ok thats. my amp is an aq-3500.1. i only asked becuase a person purchased both the wire and lugs from sky high, and the 1/0 wire did not fit the 1/0 lugs. they had to get the 2/0 sky high lugs to fit the wire.
Their lugs should fit there wire.... I just installed 2 of their spools, 60+ lugs and 70+ shrinks
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
damn 60 lugs. well thanks for the info. ill be putting my order up in the order post.
Tip... Don't twist the 1/0... Leave it straight, goes in the lugs easier. At least I found so.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
another good tip thanks. cuase i sure was gonna twist the wire. lmao.
