Ok, i am going to make an effort to test an amplifier each week, or at least every other week, and post up a video. I know today is only Monday, but i wanted to see if you guys could guess what this amp REALLY did. It's about 6-7 years old.
Rockford Fosgate T800.4 (4channel)
Rated: 200x4, 400x2.
I tested it @ 2ohms (1 ohm bridged). I used a battery bank of 3 xs power XP3000 Batteries for 12.8v, to simulate the car being off..... and 3 D1400 for the 14.5v test, simulating the car on and alternator turning. Both banks are sitting on a 10 amp intellicharger, to keep the batteries fresh in between runs, but they are FAR from a power supply @ 10a, so they don't factor too much, other then in between tests.
Bear in mind, my test bench is FUN but it isn't perfect. It's only 3 batteries in each division. It is good up to about a couple thousand watts IMO before the batteries start becoming a larger deciding factor. That is what the AD-1 is all about though. Your results are ALWAYS going to be affected by the power you are supplying to the amp, that is being tested. It is made to be brought out to the car. The true beauty of the amp dyno is, i actually test this amp in YOUR car (when you pull up) and i tell you if your amp is really putting out the power, with the electrical system YOU provide (aka your car). So this test is fun, but remember, it is based SOLELY off of the power i am able to give it from my bench. So take the results for what they are....
Categories: (tested @ 2ohms bridged on front and rear channels).
Total: front/rear combined
12v @ 1% distortion
12v @ Clipping
12v dynamic RMS @ clipping
14v @ 1% Distortion
14v @ Clipping
14v dynamic RMS @ clipping
any guesses? I will post up the video and results tomorrow, as it will finally be "Tuesday" :D
Follow my Tweet (Twitter)
I want to make this more fun:
add up ALL THE NUMBERS COMBINED from:
Categories:
12v @ 1% distortion = xxxx watts
12v @ Clipping = xxxx watts
12v dynamic RMS @ clipping = xxxx watts
14v @ 1% Distortion = xxxx watts
14v @ Clipping = xxxx watts
14v dynamic RMS @ clipping = xxxx watts
and post up the number....the person who hits the EXACT number, will get an SMD VM-1 Volt Meter OR the new SMD OM-1 Output meter when we release it in a few weeks. (see the meter's below the AD-1 :D)
let the games begin :D
all combined... 2023 Watts!
Edit: 4751 watts! :D
Edited by cjvue
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
4ohm
12v @ 1% distortion : 178X2
12v @ Clipping : 185X2
12v dynamic RMS @ clipping 172X2
14v @ 1% Distortion 215x2
14v @ Clipping 235x2
14v dynamic RMS @ clipping 225x2
2ohm
12v @ 1% distortion : 360x2
12v @ Clipping 374x2
12v dynamic RMS @ clipping 368x2
14v @ 1% Distortion 412x2
14v @ Clipping 431x2
14v dynamic RMS @ clipping 425x2
all 3 categories @ 12v and 14? damn, low ballin! :D
4ohm
2ohm
no need for 4 ohm ratings. I just did 2ohms bridged (1 ohm). Oh and put up a total so i don't have to do the math :D
1 guess per person please and NO editing! thanks!
I suck at reading
Edited by donpablo
2015 F-150 Platnuim
4,862 watts...that how you want it posted?
Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are!
I'm not compensating, just proud of fabricating!
My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts
http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19
yup yup.
if that is the total 12v (all the categories) and the 14v (all categories) combined......
