1996BLKBauer Posted June 26, 2013 Report Posted June 26, 2013 OK, so I am doing a custom dash on my Explorer, and what I want to do is have USB plugs so that I can charge my phone, and GPS while driving, without needing the large, bulky adapters out of a regular 12 plug, Anybody know where I can get regulated female USB plugs that I can have on my dash? I am OK with mounting the regulators behind the dash, I am just tired of the damn things taking up room in my glove box. I keep searching on Google for regulated female USB plugs, and it really doesn't show me what I need... 1996 Ford Explorer Eddie Bauer V8 AWD So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
Chris Hammer Posted June 26, 2013 Report Posted June 26, 2013 Disect a 12v to usb adapter..then hard wire it in, and run a male to female usb extension...glass the female side into the dash.. Just an idea. MY BUILD *****http://tinyurl.com/gmcbuild***** Vehicles 2005 GMC Canyon CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.) crf250r - Used to be race bike..now I just trail ride..practice at the track on it. CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg Sold to: Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585 Shower farts still piss me off.I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
n8ball2013 Posted June 26, 2013 Report Posted June 26, 2013 monoprice.com THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Nasty1 Posted June 26, 2013 Report Posted June 26, 2013 All I did was buy a few USB cords ,some abs plastic , and a lot of time and cusing..... But it looks factory . I cut all the holes with a dremel at a low speed. 2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz 19 cubes net 245sq in of port Sundown 3500 @ .7 Ohm Sundown 100.4 Rockford Fosgat Power Series 5.25 Dash 6.5 Kicks 8 Coaxils Doors 250 mechicman alt 1 red top under the hood 2 yellow tops in back big 3 with 1/0 knukonceptz wire 3 runs of +/- 1/0 knukonceptz wire IT LBS
1996BLKBauer Posted June 26, 2013 Author Report Posted June 26, 2013 Disect a 12v to usb adapter..then hard wire it in, and run a male to female usb extension...glass the female side into the dash.. Just an idea. I might have to do this, I did find a 12volt to 5 volt adapter on Ebay http://www.ebay.com/itm/Buck-DC-Volt-Converters-12V-to-5V-1A-In-Car-Power-Supplies-Dual-Cable-USB-A-Plug-/350814269124?pt=LH_DefaultDomain_0&hash=item51ae28eec4 But I am unsure if I trust it with charging my iPhone for any amount of time... monoprice.com Thanks, I'll check it out. All I did was buy a few USB cords ,some abs plastic , and a lot of time and cusing..... But it looks factory . I cut all the holes with a dremel at a low speed. How did you attach the Female ends to your dash? not much to grab onto to make a flush mount... 1996 Ford Explorer Eddie Bauer V8 AWD So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
Nasty1 Posted June 26, 2013 Report Posted June 26, 2013 I bought 1foot USB exstention cords , cut the Opening out for the end. Then cut that piece out and glued it behind the piece that I cut to fit the hole in my dash. Sorry about the spelling. It sounds confusing but it's really easy 2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz 19 cubes net 245sq in of port Sundown 3500 @ .7 Ohm Sundown 100.4 Rockford Fosgat Power Series 5.25 Dash 6.5 Kicks 8 Coaxils Doors 250 mechicman alt 1 red top under the hood 2 yellow tops in back big 3 with 1/0 knukonceptz wire 3 runs of +/- 1/0 knukonceptz wire IT LBS
Nasty1 Posted June 26, 2013 Report Posted June 26, 2013 I glued the base of the USB to the first piece of abs and when u add this to the piece to the outside one it sits flush. 2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz 19 cubes net 245sq in of port Sundown 3500 @ .7 Ohm Sundown 100.4 Rockford Fosgat Power Series 5.25 Dash 6.5 Kicks 8 Coaxils Doors 250 mechicman alt 1 red top under the hood 2 yellow tops in back big 3 with 1/0 knukonceptz wire 3 runs of +/- 1/0 knukonceptz wire IT LBS
1996BLKBauer Posted June 26, 2013 Author Report Posted June 26, 2013 I bought 1foot USB exstention cords , cut the Opening out for the end. Then cut that piece out and glued it behind the piece that I cut to fit the hole in my dash. Sorry about the spelling. It sounds confusing but it's really easy I glued the base of the USB to the first piece of abs and when u add this to the piece to the outside one it sits flush. Alright cool, I am pretty sure I understand what you mean. Shouldn't be that hard though, I'll just have to use my imagination. Like on the whole dash. 1996 Ford Explorer Eddie Bauer V8 AWD So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
775Tundra Posted June 26, 2013 Report Posted June 26, 2013 To make it look clean gut the 12v to USB( which should already lower the voltage to .5 or 1v) then use the flush mount USB adapters. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
1996BLKBauer Posted June 26, 2013 Author Report Posted June 26, 2013 To make it look clean gut the 12v to USB( which should already lower the voltage to .5 or 1v) then use the flush mount USB adapters. I was considering using one of those, BUT I have had nothing but bad things happen with them. First it fried my old BlackBerry, and then again, another one fried my Samsung Galaxy SII, Although they have the flush look, I refuse to use the electronics from them at all. 1996 Ford Explorer Eddie Bauer V8 AWD So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
