T2 making noise -.-
Did you check out the leads to make sure they dont hit the cone? Better to try all possibilities
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
the leads are sandwiched between spiders... integrated? I think they call it.. idk lol
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
i had a t2 12 that i had a similar issue with. had it in a 3-3.5 cuft box ( dont remember for sure ) tuned to around 40hz. turned out it was a blown coil and i didnt realize it until i put a t1500.1 on it (big mistake in such a big box but live and learn) burnt that sub up real bad but oddly enough it was playing for a good 2-3 months like that until i put it in a 2cuft box tuned to 40hz slot port. after about 3 months in that box it started smoking like crazy. got it warrantied. the local shop i got it from just traded me out as rockford tech told them to.
thats my own exp but was in way to big of a box for the power i was running. might not be the same issue your having but if it is i hope the place you got it from will warranty it.
I had it in an almost 4cbft box lol that's big... also, for a month or so had it at 1 ohm on my friends hifonics 2100 brutus.... hope its not blowing
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
well those subs are suggest at a 3.75cuft box slot port by rockford. 2.5 with round ports. it might be blown and if you didnt get it from a authorized dealer you would be sol. rockford might fix it still but most likely at a price.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
really? I only see 2.75 and 3.25. anyways, I guess ill just play it by year, its not from an authorized dealer **puts gun in mouth** so I guess ill just play it till it fucks up and then hit up fixmyspeaker. I have an x 18 coming so maybe I can sell it fucked up?
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
sell it how it is now. get what you can for it. im sure there is a young fanatic that will take it.
then use the money to upgrade.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1191 Guests (See full list)
