DylanBunch Posted June 26, 2013 Report Posted June 26, 2013 My t2 15 is making a noise that sounds like the cone and dustcap hitting and idk what to do about it. Didnt buy it from an authorized dealer (audiosavings) so rockford won't do anything about it 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Amart88 Posted June 26, 2013 Report Posted June 26, 2013 If you push on it does it make any noises? Does it do it on all notes or just the lows? My 2005 s10 blazer build. 4 zcon 18's walled.
DylanBunch Posted June 26, 2013 Author Report Posted June 26, 2013 If I tap or push its fine. On any note in box or out, mid to high volume 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Amart88 Posted June 26, 2013 Report Posted June 26, 2013 If I tap or push its fine. On any note in box or out, mid to high volume Do you have the gasket on it? I read a while back that sometimes air leaking aound the woofer can make those sounds IIRC. Also some people mistake port noise with it as well. My 2005 s10 blazer build. 4 zcon 18's walled.
DylanBunch Posted June 26, 2013 Author Report Posted June 26, 2013 Didnt come with a gaskrt, just some trim ring thing and I doubt that thing will stop and airleak. It just started a couple weeks ago, it wasn't after I took the sub out and put it in and the noise started. It literally just started one day when I turned the music up 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Kyblack76 Posted June 26, 2013 Report Posted June 26, 2013 Pull it... free air it.. with a sweep..... Get your eye balls all over it (i know its hard with the RF weird O basket thing) But, watch and listen and smell....while its out.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
DylanBunch Posted June 26, 2013 Author Report Posted June 26, 2013 Pull it... free air it.. with a sweep..... Get your eye balls all over it (i know its hard with the RF weird O basket thing) But, watch and listen and smell....while its out.... I did that already..... sweep and music, all notes. Coil is fine, never got smelly, still wounds properly 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Kyblack76 Posted June 26, 2013 Report Posted June 26, 2013 And it never made a weird sound? Then you put back in the enclosure and it makes the wierd slap noise ? Correct? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SGTSKIP Posted June 26, 2013 Report Posted June 26, 2013 What size is your box, port area, and power...... Does this smell funny to you? Its your sister
dfoland93 Posted June 26, 2013 Report Posted June 26, 2013 It could be the tinsel leads hitting the cone when the sub moves, IIRC my friend had the same problem The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine
