Hello!
I thought to made little story off my project.. :)
Car is Golf IV 99´
Setup now:
Alpine CDA-117Ri + PXA-H100
8x Sundown Audio SA-12´s
4x Focus Acoustics FX-1500d and 0.5 Ohm each
5x75Ah Optima Yellow Top and 48Ah optima in front ~150kg
3x Focus Acoustics Fx-4150 4ch amps
3 pairs x Ground Zero Hydrogen GZHC16X series mids
10 x Rainbow CAL20silk tweeters
4 x GZHF652X
My team site,there you can find more project pics and vids etc. http://www.facebook.com/pages/NoDeMo/143748795725445
So first of all, my english is not very good, but I try still..
How everything began:
15" Focus Acoustics Black MK3 + FX-1500d 1ohm
2x 15" Focus Acoustics Black MK5 + FX-1500d 0.5Ohm. Best score 146.4dB Maxboom race average.Maxboom is bass race in here Finland. Simply..competitors play same race track: 35hz,38,41,44,47,50,53,56hz 32 seconds and then calculated average..That was two years a go. Now song is 16 seconds and you can choose 32-53HZ,35-56Hz or 38-59Hz tracks,what works best in their own setup..That´s it..more www.maxboom.fi
3x12" Focus Acoustics MK5 Blacks and 2x Focus Acoustics FX-1500d 0.66Ohm each. I played this setup +150dB..
4x Focus Acoustics MK5 12" & 2x Focus Acoustics FX-1500d 0.5Ohm each. I played this setup 148.7db at maxboom race average.Total peak was 151.8db 50Hz and tl sensor middle of the windshield.
And then it goes wild.. :D
And then some car pics..
Demo race vote.. :D
Then..my doors looks like this
Ground Zero Hydrogen series mids 3pcs per door and Rainbow Dream Line CAL20silk tweeters 5pcs per door.
What those are.. ;) I write later more story what is going on now ;)
Stay tuned and comment pls :)
This is how it was created.. :D
5x75Ah Optima Yellow Tops & 48Ah yellow top..one 75Ah and that 48Ah missing from the picture..
I was lazy.. :D
Double panel (30mm)
Primer coat
Painted..
Making space for power cables :D
Box inside the car..and batterys attached their places..Power cable is 70mm2 welding cable
Some power.. :)
More story coming soon.. ;P
Thanks ^_^
Okay,moving on..
Cover plates/extra panels finded their places and two subs sitting in their place :) ..And box is attached with truck beds etc.. :)
I used leather imitation..
Front end amps find their place and front end amps wiring almost complete :)
Sub amps cables,I used 70mm2 welding cable
Amp plate :)
Amps attached
Wiring almost redi :)
Green light is always good.. :D
http://www.youtube.com/watch?v=5Ik08fECZio&feature=c4-overview-vl&list=PLMvLRhcJf9A9nbUHTRgC5VDP2nTIocbXh
More story coming later.. :)
Thanks :) Yeah,I will!
Coffee break port planning.. :D
950cm2
So..only the rest cover plates missing 8)
Good way to connect several cables together!
Sub wires..each coil gets own 8mm2 wires
First termlab measure :P Subs was played abaut ~4 hours =)
http://www.youtube.com/watch?v=wYnGAq9bFUI
This vid was filmed when subs was played only 2-4h.. :D
More coming..comments pls! :)
  • Who's Online   1 Member, 0 Anonymous, 1709 Guests (See full list)
