I had my alternator built to 250 amps and a idle it charges a 11.5 volts and the shop that built I said that's normal but I cant have nothing running at idle of my radio shuts off but once my rpms go up above 1500 it starts charging at 14 volts is this normal or is my alternator messed up
my audio im running is not big just 1 10 in Rockford t1 on a 1000 watt nitro amp so nothing big to bring the volts down
Normal for a modified stock alt, the best you can do with it is get a smaller pulley and hope it brings the rpm's up high enough to charge at idle.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
put a smaller pully on and didn't do anything different my old car I had the alternator built to the same specs and had no problems and that car the system was way bigger
Guest DC Power Kyle
Year, make, model, engine of the car that's having issues?
Also, year, make, model and engine of the previous vehicle that had no issues?
new car is 99 Pontiac grand am with a 3400 motor in it im running one 10 in Rockford t1 with a nitro 1000 watt amp
old car was a 94 chevy beretta with a 2.2 in it I was running 4 15 in Rockford p2s on 2 Rockford 1000 watt amp
I wish I just went to mechman in the first place but I went to a local shop that a lot of people said was good its called hanks in Tavares fl
