onesantaever Posted June 29, 2013 Report Posted June 29, 2013 ok so i just bought a trooper and 3 out of 4 speakers are blown so i wired up some mtx 3 ways that i know work and it played for about a min and than stoped im not sure if it has a stock amp the front speaker has 4 wires that go to the speaker and in the rear their is two and its a stock radio tape deck ftl and help would be much appreciated
john253a Posted June 29, 2013 Report Posted June 29, 2013 Constant 12V+ Red/White Switched 12V+Orange/Yellow Ground Black/Yellow Antenna Trigger Brown/Red Front Speakers 6 1/2" Doors Left Front (+)White Left Front (-)Red/White Right Front (+)Gray/White Right Front (-)Green/White Rear Speakers 5" Rear Pillars Left Rear (+)Yellow Left Rear (-)Blue/Yellow Right Rear (+)Orange Right Rear (-)Orange/Black check the wiring and colours, make sure to disconnect the cables from the h/u and check none are down to earth with a dmm, if all else fails buy and aftermarket h/u and install it with new speaker wires
onesantaever Posted June 29, 2013 Author Report Posted June 29, 2013 ok thanks and by down to earth im assuming you mean grounded correct
HatersGonnaHate Posted June 30, 2013 Report Posted June 30, 2013 Yes, earth/ground, same thing My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
john253a Posted June 30, 2013 Report Posted June 30, 2013 No I mean disconnect the speaker and head unit wires and check if the speaker wires are earthing out on the body,something the fray where they go through the door or around the heater controls Put you dmm to reactance and when you touch them together it should beep and or register a number So you put I on body and other to 1 speaker wire at speaker
onesantaever Posted June 30, 2013 Author Report Posted June 30, 2013 well what happened is the connector that plugs into the back of the stock radio if i move the wires around the speakers work so im just going to get an aftermarket cd player and ditch the connector all togeather thanks for the help
john253a Posted June 30, 2013 Report Posted June 30, 2013 If what you describe is happing idd say that shot fix it
