i have a bosch relay. i want to run the remote turn on for my 2 amps and i also want to be able to turn on a pair of fans that keep my monoamp cool. the fans only have a pos and neg wire with no remote turn on. how would i wire this to do just that. just for more info its a bosch 12 v 20/30 a
in case you still confused I have one in my setup
85-Positive trigger Remote Wire from head Unit
87-Fused with a 5amp fuse from battery 12 volt + ( optional ) but id rather this blow and kill all my devices first just in case.
86 is ground
30- Run this to a mini distribution block it will output constant 12 volts + when on to any device needing remote turn on and its also 12 volts like i said so it will power your fans.
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
Diode is not necessary dont sweat it.
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
Your best bet is to get the deluxe kit here:
http://www.ceautoelectricsupply.com/turnonrelaykits.html
It has almost everything you need and you can see the diode in the center of the relay. the diode is there for protection against "spikes".
The "spike" occurs when the current to the coil is suddenly turned off. The magnetic field around the coil collapses, which "tries" to keep the current flowing in the same direction as it was when it was powered. This can cause very high peak reverse voltages unless there is a reverse-EMF diode (sometimes called a "flywheel" diode) installed. The diode provides a path for current back through the diode.
Rolex you sicken me.
Just let me finish my pie
~ Juice
I've gotten away with no diode for many years too with no issue. just wanted to point it out though since I'm always preaching there's getting it done and getting it done right. And I know someone would chime in and say, "Hey your drawing has no diode!" lol
~ Juice
  • Who's Online   0 Members, 0 Anonymous, 524 Guests (See full list)
