5v preout and a pac1... to much voltage?
Ok guys here's the issue I'm having.
I don't have a ground loop issue. I have a rubbling just from the subs. I have an eclipse 5030 5v preout. Doesn't matter what amp I use the problem still persists. I'm on my 3rd pac1 bassknob. When I'm at 0 on know rumble goes away. If I'm at max on bass knob problem goes away. Anywhere from minimum to max on the knob I get the rumble. Could the 5v preout be to much for the bassknob. This problem happened when I was running 3 sa8's off a rf power 1000.1 amp and my temp setup is a 500.1 JL amp on 2 w0 jl 10's.
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
You are getting noise thru the pac some how.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
Sounds like a bad ground somewhere or maybe noise is being introduced due to the routing of your bass knob. I'd double check the grounding and maybe re route the bass knob wiring. Oh and, check that it isn't nicked somewhere. It's wired with black satin 6 conductor telephone wire isn't it?
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
Its not a ground issue. I can replace knob and no rumble for like a week or more then the rumble starts. Not being a dick but start your own thread bro
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
Try putting a ground wire around the ground side of the RCA at the PAC on the input side then switch to output side, see if change in sound. That should help you find your problem.
Evo X build log
I will try that bro....but when I remove the PAC the problem never returns. This is what confuses me the most. This is the 3rd one I've installed.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
Do you swap RCAs when you remove it? possible bad RCA?
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 666 Guests (See full list)
