Polarbear Posted July 8, 2013 Report Posted July 8, 2013 ok guys here it is.. I am wiring up my 2 12 xl's dual 1 ohm.. I am trying to wire them to 1 ohm so I put it in series and parallel, but it only ready .5 on my multi meter. Its really starting to piss me off.. idk whats going on!? 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
lolitskasey Posted July 8, 2013 Report Posted July 8, 2013 Check the coils on the subs to make sure they are d1.
Polarbear Posted July 8, 2013 Author Report Posted July 8, 2013 they are I did that right when I opened them up... all 1 ohm readings. 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
Rockford96 Posted July 8, 2013 Report Posted July 8, 2013 Check the resistance on the dmm leads they may be right and it kust be the leads in the dmm My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Polarbear Posted July 8, 2013 Author Report Posted July 8, 2013 that's what I thought, it might be my dmm but when I put it on the coils it reads 1.0..? 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
Polarbear Posted July 8, 2013 Author Report Posted July 8, 2013 so you think its just my dmm messing up? 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
lolitskasey Posted July 8, 2013 Report Posted July 8, 2013 either that or something is wired wrong. I know my dmm is off by like .1
Polarbear Posted July 8, 2013 Author Report Posted July 8, 2013 so I plugged it into my amp anyway to see how it works.. its not as loud as it should be? deff something is not wired right but I tripled checked and everything maybe I will figure this out! 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
Tarball Posted July 8, 2013 Report Posted July 8, 2013 Check you polarity with a 9v battery. Pos to pos on each coil. Make sure the speaker cone move the same direction oneach coil. Like you said....something iisn't right. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Rockford96 Posted July 8, 2013 Report Posted July 8, 2013 Is there a tinsel lead or something thay could have came off maybe? My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
