help?! makes no sense?! wiring..
ok guys here it is.. I am wiring up my 2 12 xl's dual 1 ohm.. I am trying to wire them to 1 ohm so I put it in series and parallel, but it only ready .5 on my multi meter. Its really starting to piss me off.. idk whats going on!?
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
they are I did that right when I opened them up... all 1 ohm readings.
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
Check the resistance on the dmm leads they may be right and it kust be the leads in the dmm
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
that's what I thought, it might be my dmm but when I put it on the coils it reads 1.0..?
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
so you think its just my dmm messing up?
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
so I plugged it into my amp anyway to see how it works.. its not as loud as it should be? deff something is not wired right but I tripled checked and everything maybe I will figure this out!
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
Check you polarity with a 9v battery. Pos to pos on each coil. Make sure the speaker cone move the same direction oneach coil. Like you said....something iisn't right.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 737 Guests (See full list)
