14 volt system help
im thinking about doing a 14 volt system and wanted a "idea" of how many battery's to use for two bc5,500D
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
What sort of alt power do you have? You running at .5 ohm or 1 ohm?
i believe the alt will be a 220 and it will be at 0.35 (before imp. rise) each amp
I'd say at least 10.. You will be drawing 800-1000 amps so minus 200 a alt battery's have to pick up slack... I have 1000a of alt an 6 xs 1400s an will drop at idle easy oh on 2- crossfire 8ks
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Shoot for around 1 d1400 for every 100 amps of draw. Given how low you are wired I'd say no less than 10. Especially with that alt. You'll be relying heavily on your batt bank for this. So the less load you have to put on each battery and the shallower the cycle (aka more batteries) the easier it will be on them.
Edit: Ninja's lol
thanks guys
