So i got in an accident about a month ago and my allignment went all crazy on me. So i got an allignment done and now im getting what i think is steering bump. When ever i go over a heavy pot hole, dip in the road or something similar my car will jerk to the right. Also my wheels up front will flare out on top, going outwards. The steering is straight but it feels terrible. I know i need new front shocks soon, lower bj, and cv joints. But does anyone have some advice on how to fix this? Its kind of scary to drive on the freeway. Are their any simple solutions?
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
Alignment shops dont know dick. They tried to charge me for a four wheel alignment when I have a solid rear axle.
You need to know your shit so you can tell them what is wrong nd what to fix.
SMD Super Seller
My Feedback Thread
I hear ya, thats exactly my point. No decent alignment shop would do an alignment without checking the wear items first.
Sounds like the k member is broken or something along those lines letting the control arm shift around, i would not drive it till you get it off the ground and really inspect it to see what broke and replace it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Its on a 02 Isuzu rodeo which is rack and pinion so it doesnt have a k member i think. But i was thinking the control arm might be messed up. I know the lower ball joint will correct some camber and shocks for most of what i believe the problem is. But i have no access to large jacks so im in a bind
No Engine
Well my car is lifted 3" in the front and i ended up breaking my factory jack so now i use a small 1.2ton jack. Yeah ive done upper and lower, they arent too bad
No Engine
  • 3 months later...
im in the same boat with my lincoln mark viii. got in a wreck which broke the tie rod and put i 90 degree bend in my lca. replaced them and did my own alignment and has been great for about 9 months until recently i started getting bumpsteer. it wasnt bad at first but over the past 2 weeks its starting to get scary. from all my research it has to do with the tie rods and/or the rack and pinion. im going in the morning to get a used rack to get me by till i can afford a reman one. and your best bet is to read up on diy alignments if your gonna keep driving it that way. i've had to re-align mine once a week for the past 2 months and orionstang is right shops dont really know jack and will charge u for shiz u dont need or not replace anything so u will keep bringin them your cash
heres a link that taught me. dont worry about the type of car they are using because the principles apply to basically everything.
http://ls1tech.com/forums/suspension-brakes/1565421-diy-poor-mans-wheel-alignment.html
  • Who's Online   0 Members, 0 Anonymous, 1594 Guests (See full list)
