XS Power
I have a D3400 underhood, that runs everything. I have the i-Bar551 Side post kit.
I am going back to using my OEM cables on the side, & want to use something like this
http://www.sonicelectronix.com/item_17747_Stinger-SHT303.html on the top for my other connections.
Can I use the 551 kit I have now & this 580 Brass terminal kit for the top http://www.sonicelectronix.com/item_38803_XS-Power-580.html & be all set, or is there a different i-Bar kit I must buy to go top & side post mounting the way I have described?
Hopefully I was clear in my explanation.
Thank you, Folks.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Bump ... little busier now ...
Thnx.
Zeke
'14
Pioneer FH-P8000BT
Yes you can use those,I have the same setup on my D3400 using OEM cables on side but I'm using RF battery terminals on top.. 2013-03-10194158_zpse1bafbb8.jpg
^^^ Thanks! The 580s should work fine for you.
Thanks a ton, both of you guys! Just ordered the post kit.
Zeke
'14
Pioneer FH-P8000BT
