new build it was a fast i didn't get all the pics, but this a temp set up. the sub is a DD 1508 d4 wired @ 2 ohm gains are turned down
the box is on the big side 1.25 cf 4" areo 17" long tune to 37 HZ . i just used scrap wood, that i had waiting to get new subs the amps that im running are RF p1000.1 bd and mid high amp is p400.4 running active on AQ components the subs, that i want i haven't decided yet
I'll add you to SOTM but you MUST ADD MORE PICS with the amp and have them up by the 22nd or I will remove you from the running.
Thank you
NoFearX18 said:
Thank you
ok i will
Looking good. Like the color of the box.
thanks
I'm going to build a better one soon i used some old scrap wood . that i had laying around , I stained it with dark walnut
sub amp P1000.1 bd its a little dusty
P400.4
the vid i will get another one later today
http://youtu.be/UIBgSrtLRwU
