Noob help
LEVENDIZ
You can get two wicked nice subwoofers for $1000, but they might vibrate the bolts out of your car. Cruise around on the forum here, there's lots of good brands to choose from...
Most folks here are going to say that same sort of thing: If your still running stock, make sure you have the means to power your system. I'll leave it at that.
Sundown is releasing their 'X' series soon, those have nice big surrounds if that's what you're looking for ( real thick rubber ). Also, remember that building the enclosure is very crucial to satisfaction, so if you get a good quality driver but cut corners on the enclosure, sadness begins.
^_^
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Soundqubed sdc2.5 10 and there 1200w amp run it at 2 ohms in a custom ported box.
Edit: and its going to be hard to "limited" the rattle and vibes. Hitting hard and vibes go hand and hand.
This is a BMW. Not a Tercel. And he said he has a budget of $1k for the sub. And that's your suggestion? Lol.
OP- a budget of $1k for the sub leaves it WFO (wide fuckin open). you can basically have any damn sub you want with that other than something exotic like a DDZ or UL12.
I wouldn't suggest more than maybe 1500w or so. Our batteries are beefy, but any more than that is pushing it.
hay he said he wanted limited vibes lol so thats what i thought of. I was going to say get a HDC3 10 or 12 and a 2200w amp but that would shake the whole car wich he does not want lol. thus i went cheap as hell MUHAHAHA. sorry my mind is not all here right now please leave a messasge after the beep......BEEP
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
ok i will step it up a bit yo can go with the FI BL 10 fully loaded on a 1500w rms amp in a custom ported box. It will give you Plenty of thump but it will rattle your car. The downside of bass IT RATTLES
141 on music.
Thanks guys, i didn't mean rattle in the sense of the car, i was under the impression you could buy a sub that had a big clean thump and not as many of those little vibrations that come from most (all) subs? Unless it just depends on the type of music you listen too...
I have never heard a sub *rattle* unless it was in a bad box what was falling apart. Big clean thump comes from clean power going to the sub form the amp, a good box, electrical in the car to support the system, and a good sub. If you want BIG thump you can get that from a 10in sub. The FI BL 10 i suggested or Soundqubed/AQ HDC3 10 will produce that with ease. Just put a good 1500w or 2k and tune the amp with a DD-1 or O-scope and you will have what you are looking for. BUT you need to make sure if you go that high you have the Big3 done and at least a second battery in the trunk. (im no expert on electrical so you may need more) As for amps SQ has a 2200 that is not badly priced and does rated. There is also RF Sundown DC crescendo...ALOT of good amp companies out there. Take a look on this fourm and read some reviews on some different types of subs and different amps. If you have a question about any of them DONT be afraid to ask just dont do it as AMP A vs AMP B or sub A vs sub B.
141 on music.
Thanks dude, i don't wish to run a second battery... i'll have to workout exactly what i'm limited too, maybe such a powerful sub isn't going to work for me.
No problem man just brouse on the fourm and read alot and learn (what i did) there is alot out there as in choices and everybody on here is very friendly and willing to answer any questions.
141 on music.
Thanks bro, will do :)
since where all throwing in suggestions...
1 DAD BD 10...
http://showtimecaraudio.net/shop/10/2000-watt-peak-10-high-performance-sub-d2-bd-10d2/
more or less sound quality woofer... that gets LOUD LOW and sounds good doing it...
keep in mind in order to get a sub to sound good it needs a proper box ! ( not one you buy online those are called pre fabs.)
Yes that's exactly what i want, a high quality sound that can get pretty loud in the low range.
Btw, i listen to rap and house music if that help :)
I think what would help the OP the most with a $1000 budget is to have a list of everything he needs. From what I understand is that he has a strict stock system and needs quite a bit.
  • Head Unit
  • Everything to hookup the head unit along with an alarm.
  • Amp
  • Sub
  • Enclosure
  • Power wire, speaker wire, RCA's, Remote wire.
  • Fuses (But I would recommend OP getting a wiring kit unless he has some experience with electrical.)
I'm sure there is more just haven't thought of them yet.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
  • Who's Online   0 Members, 0 Anonymous, 637 Guests (See full list)
