Amp for SA Neo Pro 8 x2
Zak Massey
Here's a rundown of my what my set-up is;
2 Fi Bl 18's running on 2 Kicker ZX2500.1's
2 SA Neo Pro 8's running on ??????
I have this all in a 2003 Cavalier LS Coup
Now I need to know, what should I run the 2 SA Neo Pro's on?
Should I stick with my Kicker ZX line or move over to the Sundown 125.2?
I know that the ZX2500.1's are downright great amps, but I have no experience with Sundown amplifiers.
Both are easily in my price range so that's not an issue.
Any advice here is greatly appreciated!
Also will 2 Neo Pros be enough for these subs?
If there's anything I didn't cover, ask away!
'03 Cavalier LS Coup
DC Power 270xp alt
2 Sundown Neo Pro 8's
2 Selenium ST200 tweeters
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
1 CT Sounds AT7000.1D
Vs thread..?
Both amps are great. I'd be concerned less with which amp and more with the tweeters to go with those 8's... Yes they will most likely be loud enough..
But some people have different definitions of loud enough mids and highs for their bass, que carbons build. I wouldn't sit inside that car if I was paid with all those mids and highs.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Alright, Not so much intended to be a vs. thread, I'll go back and change that. Totally forgot that's frowned upon.
By loud enough I mostly mean, Will I be able to clearly hear the mid's and up over the bass?
And that also raises the question, What should I do about tweeters also?
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
u can use what ever tweet ur budget desires man. the vocals will deff get much louder to keep up with the subs. as for amps both amps are great. most like to keep things matching but in the audio world the more u try the more u have in ur favorite audio check list. u can use one 4 ch to run it all 2 of the channels to the 8's and the other 2 channels to the tweets.
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
If I ran 4 channels, 2 to the tweets, would I respectively need 100 watt tweeters?
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
No if you had a 4ch that puts out 100 watts at 4 ohms... Lets say you get 4ohm neo 8's to run a single woofer on each channel. 1&2
Then you need tweeters and you have ch3&4 open. Easy right? Well 100 watts blows most tweeters instantly. Unless you get 8ohm tweeters, then your ch 3&4 will only get maybe 50 watts because of the added resistance. Also you can give them even less watts by keeping the gain lower then it would be "properly set"
Edit IMO you will be fine on clarity and loudness with 2 neo 8's and 2 super tweeters on a 4ch. Unless you decide to double or quad your power, and double or quad your woofers then you should be fine. Normally in my experience you can hear a pair of neo 8's and some super tweets (one set per door) up to about 148-150db.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Just my experience, had two neopros 6.5" model on 55wrms, and they where loud as hell, and sounded good crossed down to 50hz. On mor epower I wouldnt cross them super low, but I bet they would take 100wrms all day crossed to 50 like I had them, I bridged 170w off my two front chennels on to one jus tto try it, handled it like a champ and was ridiculous loud for a 6.5, but midbass was gone and I had to cross at 100hz. Just my experience and 2c.
If you are worried about tweets, run multiples or higher impedance like sword said.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
My set up is easily going to be running 50-52 daily. That's why I was unsure if they would be enough. Also how do I wire in the Tweeters, will I need a crossover or is there another way to do it?
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
get an amp or headunit that has the built in crossovers to run active, or run the tweeters on a passive crossover like crescendo sells. I would wathc the gain though....that much power on tweets is alot.
Vehicles
2005 GMC Canyon
Sold to:
What are some good (cheap) tweeters? I really have no Idea when it comes to tweeters
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
  • Who's Online   0 Members, 0 Anonymous, 314 Guests (See full list)
