Cazz Posted July 30, 2013 Report Posted July 30, 2013 Hey guys I got a rockford P300-2 pushing a rockford P2D2-12 bridged at 4 ohms to give 300 watts I have the option to set the gain from 1 to 11 so I've been told always keep the gain down, I have tried to set the gain by ear using a 40hz test tone and that left me on 6, this makes the sub have no guts and doesn't push a lot of bass at all we then took another approach of using Ohm's Law we did the square root of 300x4 which was 34.64v so we did that and it also left us on 6, we want as much bass as possible but obviously we don't want to blow it, any suggestions?
Soccerballzs Posted July 30, 2013 Report Posted July 30, 2013 Hey this amp is to small for this application. Look at a P-1000. P-300-2 good for door speakers. Run 2 here for back doors. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Cazz Posted July 30, 2013 Author Report Posted July 30, 2013 ok so heres the problem I have now you have said that, thanks for the advice BUT, I have 2 P300-2 Amps and another P2D2-12 coming from America (im in the uk, cant get no Rockford over here) and I cant afford buying another amp or 2, how could I get good bass from these subs without blowing them, if I turn the gain to around 8 I can get a nice amount of bass but im scared im going to blow it. please help
hazestorm23 Posted July 30, 2013 Report Posted July 30, 2013 You could invest in a DD-1 it would help you now and in future installs. Take my word gain setting is not easy by ear I used to think the same thing to turn it up maybe half way. But with the dd-1 some of the amps I tested could only go up maybe 40% gain without having distortion. And that amp is OK and is probably under rated.
Cazz Posted July 30, 2013 Author Report Posted July 30, 2013 i dont have any money to buy a DD-1, i would have bought one if i could afford it. the DD-1 is 149.99 usd that means i would pay around £100 and that is alot, also id prob have to pay shipping fees ontop, then will probably have to pay import fees ontop, i havent got the money for that. is there no way i can be safe and turn it up or is there something that will do the job of telling me what to set it on that costs cheaper?
hazestorm23 Posted July 30, 2013 Report Posted July 30, 2013 Maybe this can help you. We first covered how to set your gains by ear in the article titled How to Tune and Adjust Amplifier Gains and Bass Boost, however this is not a great method to use because all of our ears are different and we often cant hear the most deadly distortion. For those of us with a Digital Multi-Meter (DMM), setting your gains this way is the most effective method aside from using an oscilloscope. Lets get started. Step 1: Disconnect the positive speaker wire(s) from the positive terminal(s) on the amplifier. Step 2: Turn off all EQ settings or set them to zero, such as Bass, Treble, Loudness, Bass Boost, Processing and EQ functions. Step 3: Turn the input sensitivity (gain) to zero. For most amplifiers, this is counter clockwise (CCW) to the farthest point. Make sure the input voltage selector is on Low if the amplifier has one. Step 4: Set the head unit volume to 3/4th of its maximum volume. Turn your radio dial to it's maximum volume and multiply that number by 0.75, this will get you 75% of your maximum volume. Step 5: Now we must find the voltage that we need to set the gain to. Voltage = square root of watts x ohms. For example, a 500W RMS amplifier at 2 Ohms would configure like this: 500W RMS X 2 Ohms = 1000W. Now take the square root of 1000W and your voltage should be 31.62V if youre running an amplifier with one gain control. Some amplifiers have 2 gain controls so treat it as two separate amplifiers. If the amplifier is 100W RMS by 4-channels for a total of 400 watts but has two gain controls, divide the total RMS by half and use that for your voltage calculations. (EX: Square Root of 200W RMS x 2 Ohms = Voltage for each gain control) Step 6: Make 100% sure the positive speaker wire(s) are disconnected from the amplifier. Once double checked, insert a test CD with a sine-wave test tone at 0dB level in the frequency range of 50Hz to 60Hz for a subwoofer amplifier or 1,000Hz for a midrange amplifier. Set the head unit to repeat for continuous play of the test tone. Step 7: Connect a digital multi meter set to AC Volts to the speaker outputs of the amplifier. The positive voltmeter lead will touch the positive speaker wire terminal and the negative lead will touch the negative speaker terminal. If everything is done correctly, a low voltage will be displayed on the voltmeter, usually 6V or below. If you get a high voltage right away, repeat steps 2 and 3. Slowly turn the input sensitivity (gain) up on the amplifier until the target voltage you calculated earlier is reached. Step 8: Adjust every amplifier in your system using this method; each amplifier is now set to its maximum unclipped output level. Turn the volume on your head unit to zero and turn it off. Step 9: Reconnect all the positive speaker wire(s) to their respective positive terminals. Double check all wiring and proceed to turn the headunit on. Remove the test tone CD and play a musical track that you are familiar with. Listen for any distortion in the form of buzzing, crackling, hissing, whomping, and various other noises that intrude on the instruments of your music. This is an accurate way to set your gains to prevent distortion and clipping in your system but it is not the absolute best method. If you really need it done right, use an oscilloscope which can show you if your setup is clipping and distorting or not.
