darksoul989 Posted August 1, 2013 Author Report Posted August 1, 2013 If you could go more on depth or height we can make the box bigger, but in my honest opinion 2 cubes net is huge for 1 10" driver, 2.25 might sound good on 300 watts but if you add more power you risk burning the sub up in a huge enclosure im going to say stay towards the 1.5 end since it dont think going larger would do much difference considering current box is to small and still sounding amazing lol
Hellbilly429 Posted August 1, 2013 Report Posted August 1, 2013 So if it sounds good in that box then the box I calculated should be good. But if you really want it even bigger you can 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
darksoul989 Posted August 1, 2013 Author Report Posted August 1, 2013 ima try slots and see if i have any luck, i really wish the guys at the shop i got the sub from would tell me what they did for the design i got my idea from cause everything i try aint coming anywhere near it!
darksoul989 Posted August 1, 2013 Author Report Posted August 1, 2013 ok trying to figure out how do you measure 2 slot ports and add in bracing displacement?
darksoul989 Posted August 1, 2013 Author Report Posted August 1, 2013 So if it sounds good in that box then the box I calculated should be good. But if you really want it even bigger you can ok after messing with slots vs tube ports and watching vids iv yet to find something with actual noticeable difference in sound! i did happen to find a vid of a single 12 that faced the trunk in a wide box and had 3/4plexi glass window facing into the vehicle as well ports facing into vehicle. my curiosity is now to how well that really sounds in person vs recorded sound! as well difference if flip that direction around so its opposite!
Hellbilly429 Posted August 2, 2013 Report Posted August 2, 2013 Ok, sorry couldn't get back to you sooner, but if you go aeroport they are more efficient and therefore require less port area to create the same results. So that box you designed with 2 3" aero ports would only really need 1 4" aero You do not want 2 slot ports, you would reduce port velocity greatly and loose excursion I am sure sub back port forward wouldn't sound bad at all, not sure if it would give you maximum results, but I'll let you know as one of the guys on here plans to do just that in his Neon 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
darksoul989 Posted August 2, 2013 Author Report Posted August 2, 2013 Ok, sorry couldn't get back to you sooner, but if you go aeroport they are more efficient and therefore require less port area to create the same results. So that box you designed with 2 3" aero ports would only really need 1 4" aero You do not want 2 slot ports, you would reduce port velocity greatly and loose excursion I am sure sub back port forward wouldn't sound bad at all, not sure if it would give you maximum results, but I'll let you know as one of the guys on here plans to do just that in his Neon Is curious to how that turns out then, cause with me putting Lights in the box with the ports being same side as the window and the light being on that side facing the sub, it would be less light shining through the ports. also trying to figure out easier way to calculate the window displacement. my math flat out sucks when comes to decimals and fractions! also what would be best for thickness off the box, was thinking 1.5'' so that have 0.75'' to fit the window flush with outside the box. And where to even find 3/4 plexi or acrylic glass? what i can find in stores is all under 1/4'' ( mostly 0.08'') and thickest was was 1/4'' but it was a hole dam sheet at over $150!
Hellbilly429 Posted August 3, 2013 Report Posted August 3, 2013 3/4" box with double baffle (1.5" total thickness) Not sure how the plexi would be best installed, I was thinking attach a metal frame to the plexi and flush mount it in inside the box and caulk it with clear silicone. There is an add right at the top of this website for plexi, online might be your only option for that thickness Here's a link to the build I was talking about, no lights but he will be putting a 6" aeroport on the back of his box for his 2 10"s, subs facing trunk and port firing into cabin. He will let us know how it sounds 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
darksoul989 Posted August 4, 2013 Author Report Posted August 4, 2013 3/4" box with double baffle (1.5" total thickness) Not sure how the plexi would be best installed, I was thinking attach a metal frame to the plexi and flush mount it in inside the box and caulk it with clear silicone. There is an add right at the top of this website for plexi, online might be your only option for that thickness Here's a link to the build I was talking about, no lights but he will be putting a 6" aeroport on the back of his box for his 2 10"s, subs facing trunk and port firing into cabin. He will let us know how it sounds double the thickness using 3/4'', on the side with the window, cut window size out of inner board, and outer board make it slightly wider so window fits into that. screw window in place and from inside caulk it for complete seal. thats what i figured since most bandpass designs are like that without any true seal at all. and i did figure i'd need 2 ports cause with just the current port on the Bassworx box already being 4-5'' wide and 3'' tall it produces one hellacious amount of air.
