robby512 Posted August 1, 2013 Report Posted August 1, 2013 Which would supply the best power to my system 0 gauge cca? Or 4 gauge ofc?
Azagtoth502 Posted August 1, 2013 Report Posted August 1, 2013 Need more details, amps you running ect ect pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
ChevyBoy95 Posted August 1, 2013 Report Posted August 1, 2013 1/0 CCA has more amp carrying capacity than 4 ga OFC. 1/0 CCA = 200-250a (depending on size 4400, 4704, 5200) 1/0 OFC = 250-300a (" ") 4ga CCA = 100a 4ga OFC = 150a i would suggest.... 1/0 CCA = <2000wrms (2000 and down) 1/0 OFC = 3000wrms (then double up at 3500+) 4 ga CCA = <1000wrms 4 ga OFC = 1500wrms edit: 1/0 CCA is barely more expensive than 4ga OFC, so you might want to go with 1/0CCA with the higher carrying capacity. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ZombieFatMan Posted August 1, 2013 Report Posted August 1, 2013 i believe the 0 CCA would or if you can go two runs of the 4 OFC but you could get 50' roll of 1/0 OFC for $170.00 "Walmart Where Car Audio Is Both Funny and Sad" "The weak are meat, and the strong do eat..."
robby512 Posted August 1, 2013 Author Report Posted August 1, 2013 Thank you that's exactly the info I wanted
