how to get a motor off the basket?
i have a blown pyle
http://www.ebay.com/itm/NEW-Pyle-PLSQ10D-Red-Label-Square-Subwoofer-PLSQ-10D-/360681248462?pt=Car_Speakers&hash=item53fa4716ce
i wana take the motor off and build an 8 its a pretty decent size motor uses a 2-1/2" coil so i think it would make a pretty good 8. it just has philip head screws i tried to take them out but it started slipping so i stoped cause i dont wana strip them. anyone have any tricks to get them out while saving the motor
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
screws are likely glued down to prevent themselves backing out.
Try putting some heat to it.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
might in the end have to get that drill bit that drills into screws so you can take them out
put some heat on it and I have a screw driver that is good for stuff like that it might be worth picking up if you are doing a lot of taking screws out and don't wanna strip em...you put pressure on it and hit it with a hammer and it backs out the screws for you...
http://www.harborfreight.com/impact-screwdriver-set-with-case-37530.html that's similar to what I have but mine is all metal, it works like a charm though
whats wrong with fat chicks? they are like mopeds, as long as your friends dont see you riding it, they are a blast! hahah
I am dumb as a stump. I live in the south and we are all dumb here.
Could always try the rubber band trick to get a snug fit in the screw head and try to prevent stripping in the first place. I have done that before with success.
Firm believer in letting my cars do my talking!
You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it.
"Black Pearl" Build Thread
http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1
used a little heat and it came right off. only thing now is its a 6 bolt pattern but doesnt match up to my 12 spoke 12" basket the 12spoke 8" i was looking to get is a 4 spoke so not really to sure how im gona get them to mate up
http://www.ebay.com/itm/8-basket-12-spoke-frame-subwoofer-recone-speaker-/130949494757?pt=US_Speaker_Sub_Grills_Accs&hash=item1e7d32b7e5
any advice from those who have done this kinda thing
that and in getting the specs for a coil its a 2.33 inner with a 2.57 outer. cant seem to find a 2.5 coil thatll fit or a 2" but ima keep looking
ya thats what i was thinking or re drill the motor or basket. but now thats not really the issue cause thats something rather simple to do i feel like finding a coil with those odd specs is gona be rather hard
I'm all for seeing custom subs built, but for the time and cash you are going to drop to use that motor you might just be better off buying a nice factory built 8" sub. Once you start getting into larger drivers is where you can save a couple bucks building your own IMO
  • Who's Online   1 Member, 0 Anonymous, 569 Guests (See full list)
