christamez80 Posted August 4, 2013 Author Report Posted August 4, 2013 The numbers u get are from the measurements I gave u? I used the Torres box calculator and got those numbers. Unless it's not working properly then it should be right with the info I put in it.
CleanSierra Posted August 4, 2013 Report Posted August 4, 2013 I used your external dimensions with a port running along the bottom of the box. You need much more port area than 120". A 10" by 12" port isn't going to cut it. Im not the one you want to try to troll. Just a fyi for you.
christamez80 Posted August 4, 2013 Author Report Posted August 4, 2013 With those measurements, that leaves my box 3 inches from hatch. Will that affect the sound?
christamez80 Posted August 5, 2013 Author Report Posted August 5, 2013 I tried a new box design with port on bottom. I came up with 18.05 cu ft after displacements and port is gonna be 46.5 x 5 giving me 232.50 sq in of port. Tuned to around 33.5 Hz. Does this sound right? Again I used the Torres box calculator.
