No Rent a modding
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
what size alt and how many battery do you have that could be the problem
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
That JL is fine. Upgrade your electrical. It takes power to make power.
Eclipse cd7000
big 3 is a must did mine help alot with the voltage
2 sundown sd-2 d4
flex tech
box design by Joe X
You can't get much cheaper then doing the big 3 and runing 1/0 gage wire. As finlster said JL audio amps are good amps (just cost to damn much along with all there other products) you just need the proper power to feed the amp.
141 on music.
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
