JcbPrry Posted August 10, 2013 Report Posted August 10, 2013 is a trunk wall with 2 15's possible for a 2004 ford taurus? or would I have to downgrade to 12's? 2004 Ford Taurus Kenwood KDC-352U Dash Kenwood (2) 6x8's 2 American Bass HD 15's D1 Coils Audiopipe APK3500.1 @ 1ohm Shuriken SK-BT140 Battery 8.8cu box with two 6'' aeroports, firing into the cabin All Audiotechnix 0awg
tacomaguy1 Posted August 10, 2013 Report Posted August 10, 2013 How much height do you have, 15s standing up need like 17.5" or so of baffle Team Flex Issues
Guest Posted August 10, 2013 Report Posted August 10, 2013 trunk wall? you mean firing forward? depends on the height/width of the hole where the cabin meets the trunk. and how big of a box you can build inside the trunk.
Swordlordboy1234 Posted August 10, 2013 Report Posted August 10, 2013 trunk wall? you mean firing forward? depends on the height/width of the hole where the cabin meets the trunk. and how big of a box you can build inside the trunk. Epic trunk wall thread My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
