Chris617 Posted August 14, 2013 Report Posted August 14, 2013 I just got 2 12" dual 2 ohm alpine type r subs rated at 300-1000 watts rms and i want to get a cheap amp that will power them at their full 1000 watts. Any suggestions?
Kyblack76 Posted August 14, 2013 Report Posted August 14, 2013 You could try, and ask a amplifier question,.................. IN THE AMPLIFIER SECTION, instead of the Forum Technical Support area???? Welcome to the forum...... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Skullz Posted August 14, 2013 Report Posted August 14, 2013 The problem you have, is that you got D2 subs and wiring them will only get you down to a 2 ohm load for the pair, so your options are limited on the amps available to power them cheaply enough. About as least expensive as it is going to get. http://www.ebay.com/itm/ALPINE-MRX-M110-CAR-AUDIO-STEREO-MONO-CLASS-D-X-POWER-DIGITAL-AMP-AMPLIFIER-/360717131388?pt=Car_Amplifiers&hash=item53fc6a9e7c&vxp=mtr 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Chris617 Posted August 14, 2013 Author Report Posted August 14, 2013 So what would be a good cheap amp if i got the D4
