UBL: Lbox88's 2009 Equinox
  • 5 months later...
Whoops, forgot to update this.
Sold the BRZ, replaced with this.
And the blue on the amp is actually closer to the paint on the car than the pic makes it look.
Also took the opportunity since I was going to unplug them anyways, and color coded my 4 channel RCA's with some electrical tape.
  • 3 weeks later...
Last piece came in and I picked up a new serpentine belt that is 90 1/8" so that should make up for the extra slack my tensioner has been trying to cope with. Now just have to wait for it to warm up to work on it.
The Red wire on the left is what I have installed now, Cadence 1/0 CCA, center is Sky High Car Audio wire 1/0, right is Rockford Fosgate Tinned OFC 1/0 i had a piece of laying around.
  • 1 year later...
Rough estimates on space, but I'm going to be trying for 3 10's. I'm thinking American Bass this time, 3 dual 2 XFL's so I can wire to 1.3 giving them about 1-1.3k/ea.
Depth is my unknown at the moment, will make changes as I go if necessary.
Picked up some wood to make a battery frame, and some 90o brackets to hold it onto the cargo deck. I am thinking I could use a wider board on the back side of the battery frame to hold the amp there instead of on the box, only thing is the amp will be upside down due to how the RCA's and remote are set up.
The box will be subs back port back so I can set stuff on top of it after it's finished, with the port on the passenger side so I can run the wire into the subs on the driver's side where the inputs on the amp are.
I just need to sell a couple things to get the rest of the cash to order subs, then get time to actually work on it. Need to also order a couple more fuse holders so I can run a 2nd positive up front once I move the grounds to the back and replace my current positive front run with the Sky high wire I have sitting in the garage.
God I needed to write this down so I can remember everything.
I likey.. :)
Photobucket is dicking up on me apparently, I guess when you hit 2500 images they close out that folder and when you try to put more in it they shove something out and make a new folder. So those last couple of images are supposed to be these:
Now if I decide to go back to DC's but new Level 4's in 10's I could do this:
Or could do the same in 12's with this:
Just have to get shit moved still and sell a few things.
But tonight after the wife and kid went back to bed I went out looking for a different new ground. The more I thought about it the more those two bolts under the cargo deck sounded like they would suck looking at size of the bolt, location, how I would run wires, etc.
Then I found this spot:
Measuring with the meter to ground:
These are the bolts on the front side of the rear bench seat, as you can see there are two levels of humps in the cabin floor here because it's basically molded to fit around the frame. Should be able to pull the bolts, do a little sanding and apply a little grease to protect the metal and toss my new grounds in there. I'll pull my ground that runs to the front and just cut it to fit running under the seat after I get my batteries picked up and frame built.
  • Who's Online   0 Members, 0 Anonymous, 1422 Guests (See full list)
